In an attempt to get you all to admit to your 'bling', here is a selection of the stuff I have added to my bike to 'improve' it
First up is the headlamp protector, you don't wanna know how much a new headlamp is!
Next up is the tasty blue MRA screen, lots of function and a fair amount of bling too, oh and the blue screen bolts are just pure bling....
There is a whole lot of 'stuff' in this shot; the Grip Puppies foam grips, the Wunderlich 'cruise control' throttle lock, the Wunderlich indicator cancel assist, the Optimate charging/power out lead dangling out of the front of the fairing and at the top is the mount for the Ghost Drift HD camera. Also in this shot, but not obvious, the Helibars.
The R&G front wheel carrier protector bung....
....and the side crash bungs....
Next up is the R&G clutch protector plate, you should see Costas's after his tarmac slalom....
...and the water pump protector on the left....
...and finally on the R&G front, the rear drive hub protector..
The Sargent Pillion Pod, great little time but made of coctalotium! Also in this shot is the SW-Motech Alurack complete with the extended buttons to allow the fitment of the original Sport Cases as well as the Givi boxes on their plates, not shown.
Here is the extra height I get from my home-made MV-Verholen seat raising kit, 15mm...
This is the TyrePal TPMS head unit....
....and the rear sensor unit on the alloy valve stem as the original rubber one bent under the centrifugal force of the sensor....
The clear front indicator lens, cheap from China via eBay, needed some fettling but overall really good if you hate the amber originals.
A general shot showing the BMW supplied Laser Deeptone silencer etc.
A general cockpit shot sowing the Garmin mounted in the field of 'glance'.
Awkward shot of the Garmin mount.
And finally, a disastrous shot of the Ilmberger hugger which neither use nor ornament as it doesn't keep the shite off the bike and can't be seen with the Sport Cases on.
And that is about it, apart from the bits I forgot...
Brian (who doesn't really do 'bling'
PS Apologies for some of the shots, I shall re-do them at some point after the tide goes out here in sunny Newbury, not!
