Author Topic: BikeViz Bullet lights  (Read 4907 times)
« on: February 14, 2015, 01:47:44 pm »
My Bike Viz Bike Viz bullet lights on K1200GT
Website Click Here
I made up some small aluminium brackets and gave them a spray with satin black.
I hope you find this useful
« Last Edit: July 31, 2017, 05:41:27 pm by raesewell »
Offline Paul C
  • Global Moderator
  • ...ooh, why not?
Re: BikeViz Bullet lights
« Reply #1 on: February 14, 2015, 02:39:39 pm »
They are good. I fitted a set to the rear of my GS with the brake light wired in too.
Made the brackets myself.
GSA, CCM GP450, Moto Guzzi Lemans II. Once had a K1200GT
« Reply #2 on: February 14, 2015, 02:50:07 pm »
Nice brackets
« Reply #3 on: February 14, 2015, 03:01:36 pm »
Paul, how did you connect to the brake lights, I have thought about doing this myself. I have also thought about buying a mini mill, making fabrication easy.
« Reply #4 on: February 14, 2015, 03:16:08 pm »
Had them on the bike until the accident two years ago. Now they rest in a friends K12R Sport. Had them installed under the bikes noose and in front of oil cooler. If you check you will find that the plastic has a bent and the lights fit exactly there. Sorry couldn't find a foto.
Offline Paul C
  • Global Moderator
  • ...ooh, why not?
« Reply #5 on: February 14, 2015, 03:30:33 pm »
Bike Vis used to do a widget which you wired in to the brake light circuit and the LEDs. So you get two levels of brightness, side light and brakes. Can't seem to see it on their website. Might be worth asking?
As to the milling machine I bought one of these...
http://www.chesterhobbystore.com/champion-20v-mill-3992-p.asp
However, it cost quite a bit less than that. Always worth a revisit as they often have discounted models. I also got this lathe (without cross feed) at a good price...
http://www.chesterhobbystore.com/db10-super-lathe---closed-gearbox-10250-p.asp
... in fact 18 months ago I paid around £2K for the pair plus a few bits n bobs like tools and vices.
Just spotted they have 10% off this month. Check out their special offers plus Warco do similar models... except in green! Been pleased with both of mine.
« Reply #6 on: February 14, 2015, 03:38:30 pm »
Pity you don't live closer Paul :(
« Reply #7 on: February 14, 2015, 03:42:00 pm »
I have a Chester Conquest mini lathe which I got from Ebay a few years ago.
Offline Paul C
  • Global Moderator
  • ...ooh, why not?
« Reply #8 on: February 14, 2015, 03:49:54 pm »
??? Why??? Where are you anyway?
