Author Topic: Nothing to do with bikes... Drum brake problem.  (Read 1155 times)
Offline Andym535
Re: Nothing to do with bikes... Drum brake problem.
« Reply #15 on: October 27, 2019, 02:38:49 pm »
I've managed to sort out the tight spot on the drum, by backing off the adjusters, putting some emery cloth on top of one of the shoes then putting the drum back on and slowly winding the adjuster in a bit a time while spinning the drum. Took forever but seems to have worked.
Final question is on split pins with castellated nuts. Which way round is the 'right way' and why? Do you spread the legs of the pin around the nut, or along the shaft. I don't think it makes any difference so long as you have the right size split pin, but would be interested in opinions as it's something I've often wondered about.
Offline k1200r66
  • My K bike model:: k1200r,2006
  • Modifications and add-ons:: in progress
« Reply #16 on: October 27, 2019, 05:42:56 pm »
I alway done around the nuts.
and why,because my dad show me that way of doing it. :)
« Reply #17 on: October 27, 2019, 06:45:00 pm »
The correct way to fit a split pin is with the legs bent in the same direction as the bolt. The head will then fit inside the slot in the nut. The side of the split pin is then bent over the end of the bolt and cut off so that the end does not protrude beyond the thread. The other side of the split pin is cut off and bent back over the flat of the nut so that the end is in line with the tightening face of the nut.
The head of the split pin will not fit in the slot in the nut if the ends are twisted around the nut.
« Reply #18 on: October 28, 2019, 11:15:58 am »
They will if you use very small split pins... :D
But I agree...however, trying to get very tight pins out of a nut when fitted with the head in the slot can be very annoying if corrosion has set in. Leaving the head of the pin out of the slot at least gives you something to get your side-cutters on to lever the shank out of the bolt.
Either way, as long as the legs are crossed, twisted, bent or buggered, the nut isn't going anywhere.
  • Modifications and add-ons:: Upgrade to Kawasaki H2 SX SE! 220bhp at the wheel! :D
« Reply #19 on: October 28, 2019, 11:29:54 am »
I must admit that the aesthetics of having the spilt pin positioned with the head "inside" the castelations are better but the advantages for ease of removal when the head "sticks out" easily out weights aesthetics for me.
Offline farmer
« Reply #20 on: October 28, 2019, 03:16:19 pm »
the head of the nail sits nice and flush on the nut and the other end can then be pointed whichever way you want.....smiley face smiley face !!
« Reply #21 on: October 28, 2019, 09:12:27 pm »
 :D :D :D
