Author Topic: K1300S - First Month Report  (Read 622 times)
Re: K1300S - First Month Report
« Reply #15 on: January 24, 2019, 05:49:50 pm »
perhaps the result of too much peppermint?
...or gangrene  :o
Offline sitting_duck
  • My K bike model:: 2013 K1300S 30th Year
  • Modifications and add-ons:: LED indicators, LED H7 Conversion, HP Dash
« Reply #16 on: February 01, 2019, 03:29:28 pm »
That just leaves the alarm/TPMS which Jefferies couldn't code in for me - that was £50 spent on top of the £85 for the unit from Motorworks. Question is, is the unit faulty or is it (as Motorworks suggest) just that the BMW software won't allow coding of a "used" unit. Does anyone know if the GS911 can "teach in" alarm units? Is it even always/ever necessary?
I would expect if it can't be done with ISTA/P - then it's a job for WinKfp (another bmw tool, for flashing units directly as opposed to because some stored procedure in ISTA/P says to). But, the diagnostics (ISTA) that the dealer uses would talk to the module and retreive data from it regardless of whether it can be coded or not.
If you make it down to mine as we discussed I'll be able to give you definitive proof as to whether Motorworks are talking guff (I suspect they are) as we'll either be able to talk to it or not.
If we can talk to it, should be able to sort this for you whether it's the easy way (ISTA/P) or the harder way (WinKfp).
« Last Edit: February 01, 2019, 03:33:14 pm by sitting_duck »
Offline Lotus26R
« Reply #17 on: February 01, 2019, 05:42:14 pm »
Appreciated Nick - I have two combined units now. One which responds to my fobs (so alarm works) but TPMS doesn't and one which does neither at the moment. TPMS does work with my original unit and I know that both sensors work and transmit. Great to get it working if we can so looking forward to it.
« Reply #18 on: February 01, 2019, 05:53:44 pm »
Should I get the kettle on ?  ;D
Offline Lotus26R
« Reply #19 on: February 01, 2019, 09:42:20 pm »
Never hurts in Yorkshire....
Offline slparry
    • My webspace
  • My K bike model:: K1200GT SE
  • Modifications and add-ons:: Akrapovic Exhaust, Oberon Slave, Z technics Screen, SW Motech tank mount
« Reply #20 on: February 02, 2019, 09:22:06 pm »
I bought a used alarm from a guy on the f800 forum for my f800gs
It works, responds to the fob, screams when moved when the bikes parked up etc, however it won't activate the indicators or the dashboard Led. It too refused to be coded to the bike. Turns out older ones have different firmware that behave thus.
As it does rge squealy alarm function I'm ok with not having the flashing turn signals seeing as it was cheap :)
Steve Parry
Sales @ Chester Motorrad
Oppressed since 1958
Current fleet: '14 F800GS, '87 R80RS, '03 R1100S BoxerCup, '07 K1200GT SE .... '14 R12RT LC LE :D
Offline Lotus26R
« Reply #21 on: February 02, 2019, 09:45:03 pm »
Curious. The one I have that arms etc flashes the dash but not the indicators....hopefully at least one of them will work...
