Author Topic: Replacement Battery  (Read 471 times)
Re: Replacement Battery
« Reply #15 on: December 20, 2018, 06:18:53 pm »
The hot start issue occurs when the bike is hot and if you stall it or turn it off and try to start it again straight away it give the symptoms of a flat battery. Once cooled down it starts as normal. The fix is an extra wiring loom from the battery to the starter, should be a free fix by the dealer.
« Reply #16 on: December 20, 2018, 06:41:16 pm »
...wot he said. Plus, it is a random and acknowledged problem.
Offline TurboBevy
« Reply #18 on: January 15, 2019, 08:15:43 pm »
Battery wantage....
Eh?
Otherwise, very interesting  8)
  • My K bike model:: ex K1300S Motorsport owner. Soon to be Kawasaki H2 SX SE owner
  • Modifications and add-ons:: Complete write off due to a deer!
« Reply #19 on: January 16, 2019, 05:31:04 am »
Quote from: TurboBevy
Battery wantage....
Isn't that the measure of the continuous draw that a potential new battery places on an unopened wallet? :D
« Last Edit: January 16, 2019, 08:41:20 am by black-k1 »
  • Global Moderator
« Reply #20 on: January 16, 2019, 09:23:15 am »
Battery wantage....
No, I think it's the new town plan for Wantage to increase housing density. :D
« Reply #21 on: January 16, 2019, 11:15:24 am »
Sorry Matt - that was way too predictable.
David - ten gold house points for thinking outside the battery box  8)
Offline TurboBevy
« Reply #22 on: January 16, 2019, 09:08:33 pm »
Battery wantage....
You only get 'watt' you pay for.
However. £200 is rather a lot for a motorbike battery, what....
Offline Coully
  • Jumped off Hondas to Beemers
  • My K bike model:: 2006 K1200s
  • Modifications and add-ons:: Akrapovic endcan, hugger, fenda extenda, double bubble screen ..
« Reply #23 on: January 17, 2019, 10:35:53 am »
i just wapped in the standard replacement from halfrauds ...
If it has two wheels i'll ride it, if its egg shaped I'll catch it and run with it!
Online Andym535
« Reply #24 on: January 20, 2019, 03:07:53 pm »
Don't forget that you can only charge a Li-ion battery with a Li-ion battery charger.
Is that strictly true? Surely if the battery is sold as a replacement for a lead acid battery it must have the  necessary charging electronics built in. Otherwise the vehicle's charging system, which is expecting a lead acid battery, will cause it problems. So if these fancy new tech batteries charge off the alternator then they must also charge off an Optimate?
« Reply #25 on: January 20, 2019, 03:24:28 pm »
Yes it is strictly true...unless you get one of the very new very-new-fangled batteries which are now being developed to include the fancy electronics inside them to allow charging from 'ordinary' chargers.
Go back and read the post from Turbobevy about 7 or 8 posts ago on Jan 15 and follow the links to where the makers of the new new batteries are talking about this very subject.
Online Andym535
« Reply #26 on: January 20, 2019, 05:55:11 pm »
So what happens when you put a ‘dumb’ lithium battery in the bike then? What stops the alternator overcharging it, when I gather bad things like fires happen? For me that would be more of an issue than the cost of a special charger.
« Reply #27 on: January 20, 2019, 08:42:53 pm »
The rate of charge whilst on the bike is very low. The problem with a charger is that it allows the battery to draw more charge than is good for it...
I don't fully understand the technology but if you Google the facts you will come to your own conclusion  8)
Online Andym535
« Reply #28 on: Yesterday at 11:25:57 am »
There seems to be a number of issues with them... I'll stick with lead acid.
