Author Topic: Front end squeak!!  (Read 1187 times)
Offline DoctorW02
  • My K bike model:: 2013 K1300S and R
Front end squeak!!
« on: October 11, 2018, 09:37:31 am »
Hello again. 2nd post, 2nd help request. I've noticed a clear squeaking when i pull the bike of tbe sidestand and especially when warm if you bounce / rock the bike at standstill. It seems to be coming from front end somewhere- anyone else had this / any ideas what to get checked out?
Cheers,
Andrew.
Re: Front end squeak!!
« Reply #1 on: October 11, 2018, 10:37:12 am »
Front wheel bearings,  is my fisrt thought,  the ball  joints would not create any noise just  movement especially when breaking hard .
« Reply #2 on: October 11, 2018, 10:39:49 am »
First thing to do is to eliminate brake squeak. Pull the front lever on and do your 'normal' bouncing, lifting stuff and see if it is still there. If it has gone you have the answer. If not...
The ball-joints are renowned for failing on the K but I have yet to hear one squeak.
So, to get a little more info, sit astride the bike and ease the front end up and down slowly with the front brake on. Squeaky?
Do it more vigorously. Ditto?
Wheel the bike slowly. Squeaky?
None of this is definitive but it will giive the gurus something to go on. Of course, having a glamourous assistant with a keen ear always helps in these diagnostics.
Offline DoctorW02
« Reply #3 on: October 11, 2018, 12:55:52 pm »
Thanks for replies- will do some further investigation, but may take it to a dealer for a health check!!
« Reply #4 on: October 11, 2018, 01:13:42 pm »
Probably a silly suggestion, but if you aren't on motorsport rear-sets, are you sure you aren't hitting the pegs with shins/boots and folding them up slightly, which could make them squeak? :D
I'm sure I had that on the old one. On this one I just hurt my legs if I catch them.
Brian c. 2019
Offline DoctorW02
« Reply #5 on: October 11, 2018, 07:52:25 pm »
Hi there - i have the bmw rear sets but the squeak is there at standstill and i think i can hear it when travelling sub 20ish. Gonna hopefully take itcin to bmw dealer to get them to check as i have a 3 month warranty!!
Fingers crossed something just needs freeing up or lubing!!!!
« Reply #6 on: October 11, 2018, 08:07:36 pm »
Isn't naivety a wonderful thing  :o
Offline DoctorW02
« Reply #7 on: October 11, 2018, 08:28:17 pm »
Lol🖒🖒
« Reply #8 on: October 12, 2018, 12:16:29 pm »
You're such a doom-monger young sir  ;D
« Reply #9 on: October 12, 2018, 05:34:14 pm »
Lubing is a wishfull thought and only that ,
« Reply #10 on: October 12, 2018, 05:35:33 pm »
Swot I sed innit  ;D ;D
Offline Ady00
  • My K bike model:: K1300r
« Reply #11 on: October 12, 2018, 06:13:08 pm »
I would be looking at the shock absorber mounts top and bottom, or the wishbone mounts, if they are dry it’s a possibility
« Reply #12 on: October 12, 2018, 06:18:24 pm »
C'mon Ady this is a BMW we're talking about if something squeaks it's phuqued
Offline DoctorW02
« Reply #13 on: October 13, 2018, 05:18:15 am »
Took bike to local bmw dealer - they inspected and tried lube spray, but the mouse is still in the front end. Will be booking in when back from hols as needs to be investigated further as is rather annoying - can hear it even at / above 30mph.
Here's hoping and will update when know more.
« Reply #14 on: October 13, 2018, 09:11:06 am »
OK. The WD40 thing was worth a try but we need to get down to nuts and bolts.
There isn't much to go wrong at the front mechanically. Apart from the dreaded ball-joints of course. Mine never squeaked; diabolical judder under high speed braking as if the discs were warped and a slow, low amplitude weave at about 30 in a straight line.
There have been odd reports of nuts, bolts and screws holding the front binnacle on being loose and causing a plasticy squeak. WD should find that.
