Author Topic: Akra db killer removal  (Read 1290 times)
Offline Sutty
  • Modifications and add-ons:: Autocom
Re: Akra db killer removal
« Reply #30 on: October 24, 2018, 09:57:48 pm »
My missus asked me to knock her up some weight watchers soup today, so being an obedient husband
I prepared some carrot and coriander, when I put it in the Bosch blender and turned it on the missus
Appeared at the kitchen door and said I thought that was your bike !!! I was straight on the phone to the shop to order my SC Project slip on can.
Best regards. Mick
No problems only Solutions
Offline DoctorW02
  • My K bike model:: 2013 K1300S and R
« Reply #31 on: October 25, 2018, 10:18:27 am »
I'm liking the sound from the de-baffled akro. The SC on my R is louder and a different note - i like that also (de-baffled)😎
Offline Sutty
« Reply #32 on: November 06, 2018, 01:50:29 pm »
Can's on, looks good and sounds good even with the DB killer in. I'll try it with the killer in for a bit then without to see what I like best
best regards   Mick
Offline DoctorW02
« Reply #33 on: November 06, 2018, 03:41:05 pm »
Offline Sutty
« Reply #34 on: November 18, 2018, 01:51:54 pm »
Well, the baffle is out and the sound is perfect. Done 100 MLS this morning and it sounds great on the red line in second.
Best regards.  Mick
« Reply #35 on: November 18, 2018, 02:08:55 pm »
Bladdy 'ooligan! Yer banned!!
Offline Sutty
« Reply #36 on: November 18, 2018, 02:48:47 pm »
Brian, it was one of your posts where you mentioned the "pop" on the change that made my mind up.
And you were right ! Not quite as loud as my last Blade but still turns heads. And sounds awesome when accelerating really hard.
Regards. Mick
« Reply #37 on: November 18, 2018, 06:22:32 pm »
But it pops just as wonderfully with the dB killer in Mick.
Perhaps not as loudly or agressively but it sure as hell scares the living bejeezus out of dawdling Herfordians when you snick it up right alongside their driver's door.
OK, I agree, I'm a hooligan! And I'm banned... 8)
Offline dynajohn
« Reply #38 on: December 26, 2018, 03:26:45 pm »
On the US versions with the Akra the insert is removable. If yours has a spot weld on the nut I would use a dremel tool with a cutting wheel to carefully cut the weld. That way you don't take a chance on damaging the insert. No problem in removing it to see what it sounds like I did the same thing but put it back in because all it did was increase the noise level.
« Last Edit: December 26, 2018, 09:24:45 pm by richtea »
