Author Topic: Akra db killer removal  (Read 793 times)
Offline DoctorW02
  • My K bike model:: 2013 K1300S and R
« on: October 11, 2018, 09:33:44 am »
Hi. Im Andrew and new ti this forum. Have just taken delivery of a K13S to add to my R and per above, want the db out!! Any ideas re best way to remove the little spot weld on the retaining bolt - dremel i guess (dont have!) Would tapping it with a flat head screw driver work d'you think?
Any advice most appreciated.
Cheers,
Andrew.
Re: Akra db killer removal
« Reply #1 on: October 11, 2018, 09:42:03 am »
Make sure it's the right thing to do, many have removable baffles and run with them out for a while and quickly put them back in.
Offline DoctorW02
« Reply #2 on: October 11, 2018, 09:46:17 am »
Fair point - just want to check out the different note and volume.
Cheers.
« Reply #3 on: October 11, 2018, 10:29:59 am »
As far as I know the bolt should just come out with a little brute force to shear the weld but I've never taken mine out for one very good reason; TomL took his out and promptly went mad and deaf. He put it back in a couple of days later...
Richard (richtea) discovered his very noisy, new-to-him K13S had no dB killer fitted. Dealer supplied one and hey-ho, peace and relative quiet was restored to Abingdonshire, Newburyshire, Miltonkeynesshire etc. etc.
I understand your inquisitiveness but in your position I would leave well alone and give the neighbours some peace and quiet.
Online Costas
« Reply #4 on: October 11, 2018, 10:34:23 am »
If you're looking for more noise you will find it. On the cost of some power loss at high rpms.
Offline Sutty
  • Modifications and add-ons:: Autocom
« Reply #5 on: October 11, 2018, 12:02:09 pm »
Definitely no hammer !!!!! bin there, done that F***ed it !!!!
Best regards  Mick
No problems only Solutions
Offline DoctorW02
« Reply #6 on: October 11, 2018, 12:54:36 pm »
Thanks for replies all, much appreciated😎
  • Global Moderator
« Reply #7 on: October 11, 2018, 01:10:37 pm »
Apart from when I'm in Abingdonshire or Newburyshires!
I had a terrible awful loud hilarious/upsetting exhaust on the trip earlier this year, however I've since gone back to the Akra. I do however continue to go without the baffle. But then I'm on the M4 every day and currently doing a lot of slow traffic work where I'm sticking with to be heard is to be noticed.
I take the same approach in meetings, except less (but obviously more than zero) pops and bangs.
Offline DoctorW02
« Reply #8 on: October 11, 2018, 07:48:14 pm »
Thanks again. I have an SC project can on my K1300R  and that's pretty loud but not obnoxious. I would think the akra being that much bigger should just produce a nice deep note with a bit mire noise!?
Here's hoping!!
« Reply #9 on: October 11, 2018, 08:48:10 pm »
I can confirm an SC Project is the louder of the two - by far. About a villages worth.
Right, Matt?  ;D ;D ;D
In which case, you'll probably like the baffle out of the Akra.
But the bloke behind might not.  ::)
Offline Sutty
« Reply #10 on: October 11, 2018, 11:50:43 pm »
Does the SC project exhaust fit straight on the 1300R without any mods ?
Offline peterwbaker
« Reply #11 on: October 12, 2018, 07:58:59 am »
From memory on my bike a good quality open ended spanner on the two sides of the nut was enough to brake the weld, as others have said it is loud with it out and I have it like that about 2 weeks of the year:-) Peter
« Reply #12 on: October 12, 2018, 12:09:35 pm »
Must admit that I feel a bit of a hooligan when I first take the baffle out but the fun soon wears off and I'm always pleased to refit it. Must be old age.
« Reply #13 on: October 12, 2018, 12:50:30 pm »
A loud exhaust will get you noticed, that can be a good or bad thing depending who you get noticed by  ???
  • My K bike model:: ex K1300S Motorsport owner. Soon to be Kawasaki H2 SX SE owner
  • Modifications and add-ons:: Complete write off due to a deer!
« Reply #14 on: October 12, 2018, 01:36:38 pm »
Having followed Mark on the Old Gits trip to the Picos when he had the DB killer removed on his Motorsport,  I was very glad when it was refitted.  It's really not a considerate or social thing to do.
