Author Topic: clutch issue repair procedures by John Sykes on to fjtwelve BIKE.  (Read 274 times)
Rebuilt clutch ordered from John Sykes, just watching while he haggles on eBay with a Lithuanian over the price of a second-hand K13 clutch to modify and rebuild. Should be with me in time for my week off in October when I bring the bike back over and Ocean have agreed they will install it for me.
Update on clutch progress
"Have now completed the re engineering of the clutch basket and hub/pressure plate. Ready for de greasing and assembly once its dried off. The new pack of clutch plates arrived today so if all runs to plan I'm hoping it will be assembled by the end of the week."
Royal Mail and Ocean Falmouth willing it should be in the bike in w/c 15 October. I am really looking forward to getting back to a normal clutch instead of this on / off switch, and keen to see if any of the other vibes and noises off disappear too.
"Basket is rebuilt using new main load springs and idle control spring, other new internal parts and with the 1200 engines oil pump drive. The hub (lamellar pack) has all new faces for the friction plates on the flange and pressure plate with a complete new set of friction and steel plates. I have also incorporated the the 1300 engines type of anti chatter spring withing the plate pack as hoped."
“The clutch is assembled dry (no oil other than needed for assembly) with the two main parts ready to fit. Both basket and particularly the hub with its new plates only need a further small amount of oil pouring into their centres to wet everything all over. All this talk of leaving to soak overnight immersed in oil is not required. Perhaps wishful thinking by folk who know their clutch is in poor condition.
I have also included a separate steel plate and a separate friction plate in the box. They are 0.2 and 0.8 mm thicker than those in the rebuilt hub pack. These could come in handy to save the clutch if exchanged for their thinner equivalents to restore the original thickness if there is any sign of slip due to lining wear in the distant future. Perhaps pass on to future owners just in case so that there is maximum life to be had out of the clutch and bike.
The bikes original thrust washer between basket and hub along with release bearing and hub nut need transferring to be used again. Please encourage the workshop to fit the hub without dismantling. Some try to remove the six hexagon socket head screws that compress the pressure spring as they don't have the correct large socket for the hub nut. They need a thin wall socket to fit through the release bearing carrier to tighten the main hub nut. Even new hubs have been fitted at BMW shops by dismantling first. Problem is the alignment can be disturbed and the bike kangaroos off the line the second the second it starts to move forwards.”
Re: clutch issue repair procedures by John Sykes on to fjtwelve BIKE.
« Reply #1 on: October 10, 2018, 06:47:16 pm »
I have contacted John Sykes the clutch doctor referred to on various clutch related posts on here, and a very long string on I-bmw, http://www.i-bmw.com/showthread.php?t=51004 where John uses fourhundred4 as a forum name, and he has recommended that he rebuilds and modifies a secondhand low mileage K12 clutch for me, substantially cheaper than getting all the K13 parts and mods required to fit a K12. I am waiting for the Ocean BMW quote, but think once I get it, it will be telephone numbers, and I will be asking them to fit one of Mr Sykes' specials.
john.sykes01@btinternet.com
john@vibefreev.com
John Sykes 32 Epsom Way Kirkheaton Huddersfield HD5 0LE United Kingdom
T: + 44 (0)1484 435084
M: +44 (0)7770 772456
www.vibefreev.com
« Reply #2 on: October 10, 2018, 06:49:41 pm »
Might needed to ask for fjtwelve permission before posting his posts on a new thread hope he's not mad at me.
« Reply #3 on: October 10, 2018, 07:05:22 pm »
I'm sure Martin won't mind Costas, it'll save him the effort.
Offline fjtwelve
  • My K bike model:: Night Black K1200S 2008
  • Modifications and add-ons:: Low seat, Akrapovic carbon can, BSD remap, Pazzo levers, slate grey wheels
  • Location:: Falmouth, or Schiphol, depending which day of the week it is
« Reply #4 on: October 10, 2018, 10:04:32 pm »
Nae problem I was just about to do this. Quite happy for admin to pluck bits out of my thread and put it where its useful at any point
« Reply #5 on: October 11, 2018, 08:54:13 am »
Plucking is not really in our remit, we normally leave it to the members to index their own threads and information. Once indexed it can be retrieved in the future for the benefit of everyone.  ;)
Offline fjtwelve
« Reply #6 on: October 13, 2018, 05:23:12 pm »
Man knows how to pack it courier proof
[/quote]
« Reply #7 on: October 13, 2018, 06:03:34 pm »
Excellent job. We knew John was highly recommended and indeed his job deserves all the credit.
Awaiting installation photos and review.
Offline fjtwelve
« Reply #8 on: October 18, 2018, 05:26:30 pm »
Here's the old clutch. Available to anyone else who might want to go the same route.
« Last Edit: October 19, 2018, 07:48:04 pm by fjtwelve »
Offline fjtwelve
« Reply #9 on: October 19, 2018, 07:44:04 pm »
Sorry, forgot to tell you the cost. Ocean charged me £124 + VAT to fit the clutch, labour new gasket and 18 new screws.
John charged me £620 to rebuild the clutch, and £10 for the courier
The second-hand clutch was £165 which John bought off ebay
Total £944.
Have ridden it around the block and no nasty noises or kangarooing. Longer ride to follow
Offline fjtwelve
« Reply #10 on: October 21, 2018, 06:41:54 pm »
Went out for a 150 mile blip around Cornwall today
Rather than just sticking it in 6th and droning along as much of my recent riding has been, we had a good old thrape along the A39 up to Bude, cross country to Liskeard and back along the A38. The clutch is much smoother and so is the bike. The enormous crash into 1st gear seems to have mostly disappeared. Pulling away its possible to feather the clutch, we now have a fader instead of an on/off switch. Clutchless changes especially down shifts are much easier. Getting it into neutral while the engine is running is now easily possible. Below 7000 there are a lot less vibes, in the largely still air today it was just so smooth, apart from there's a rough patch around 7000, and above that, well, I found the rev limiter again.
Just like having a clutch really  8)
« Reply #11 on: October 23, 2018, 12:09:39 am »
...an indispensable addition to most vehicles methinks  ;D
