Author Topic: Installing uprated starter wiring  (Read 184 times)
Offline slparry
    • My webspace
  • My K bike model:: K1200GT SE
  • Modifications and add-ons:: Akrapovic Exhaust, Oberon Slave, Z technics Screen, SW Motech tank mount
Steve Parry
Sales @ Chester Motorrad
Oppressed since 1958
Current fleet: '14 F800GS, '87 R80RS, '03 R1100S BoxerCup, '07 K1200GT SE .... '14 R12RT LC LE :D
Re: Installing uprated starter wiring
« Reply #1 on: August 20, 2018, 09:32:39 pm »
Nice one Steve.
Now then, as the S is a somewhat different beast, do you have the procedure for that?
Offline slparry
    • My webspace
« Reply #2 on: August 21, 2018, 12:24:15 am »
Nice one Steve.
Done :)
http://www.gwynfryn.co.uk/pdfs/additional-wiring-k40.pdf
Steve Parry
  • My K bike model:: Patriotic white, blue & red (if you're Russian)
« Reply #3 on: August 21, 2018, 10:27:32 am »
Perfecto!
Thanks Steve.
« Reply #4 on: August 21, 2018, 10:38:38 am »
You might as well complete the set Steve  ;)
« Reply #5 on: August 21, 2018, 05:08:32 pm »
I don't think he's got one for an FJR, Rae.  Not required. ;D ;D ;D ;D
Offline slparry
    • My webspace
« Reply #6 on: August 21, 2018, 07:35:57 pm »
well......
"2011-06-28 (Published by NHTSA on 2011-06-28)
Recall Summary: YAMAHA IS RECALLING CERTAIN MODEL YEAR 2006-2009 FJR1300 MOTORCYCLES MANUFACTURED FROM FEBRUARY 2006, THROUGH MARCH 2009. THE GROUND JOINT CONNECTOR OF THE WIRE HARNESS COULD OVERHEAT AND BECOME DEFORMED, POSSIBLY CAUSING AN INTERMITTENT GROUND WIRE CONNECTION. IF THE ELECTRICAL SYSTEM IS NOT PROPERLY GROUNDED, THE IGNITION SYSTEM AND/OR OTHER ELECTRICAL COMPONENTS COULD MALFUNCTION, WHICH COULD CAUSE THE ENGINE TO STALL.
Hazard: IF THE MOTORCYCLE STALLS WHILE BEING RIDDEN, THERE COULD BE A CRASH RESULTING IN INJURY OR DEATH.
Remedy: YAMAHA DEALERS WILL INSTALL AN ADDITIONAL WIRE SUB-LEAD OR, IF THE GROUND JOINT CONNECTOR HAS ALREADY BEEN DAMAGED FROM OVERHEATING, DEALERS WILL INSTALL A NEW MAIN WIRE HARNESS. THIS SERVICE WILL BE PERFORMED FREE OF CHARGE. THE SAFETY RECALL BEGAN ON JULY 8, 2011. OWNERS MAY CONTACT YAMAHA AT 1-800-962-7926.
Additional Info: OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO http://HTTP://WWW.SAFERCAR.GOV .
NHTSA Source: http://www-odi.nhtsa.dot.gov/recalls/recallresults.cfm?start=1&SearchType=QuickSearch&rcl_ID=11V338000
http://wemakeitsafer.com/vehicle-recall/Yamaha-Fjr1300-Recall-3470627
Steve Parry
« Reply #7 on: August 21, 2018, 07:55:43 pm »
No recalls on the 2013, Yamaha seem to learn from their mistakes.
« Reply #8 on: August 21, 2018, 10:25:23 pm »
Apart from my bike  only having one left tank cover (cos the other one, unlike the bike in the instructions, is the right tank cover  ::) ) that all seems perfectly strightforward...
Many thanks as always Steve and I applaud you.
