Author Topic: Quick & Easy in-depth electronic diagnosis for CHEAP  (Read 19720 times)
Re: Quick & Easy in-depth electronic diagnosis for CHEAP
« Reply #30 on: January 02, 2018, 11:33:29 am »
Under the seat towards the rear and tucked under the RH fairing panel
« Reply #31 on: January 02, 2018, 11:58:21 am »
Love those photos, if only I could download some myself. Do not mention to me Imgur...........
« Reply #32 on: January 02, 2018, 12:01:02 pm »
Excellent. Thanks Tom.
Offline sudolea
« Reply #33 on: January 06, 2018, 02:00:16 pm »
I have a small number of software classes ready (testing underway) which leaves the ("any") serial communication (e.g. also that K-Line KWP2000 diagnostic communication) in the background, while the ("any") main program thread can show or record (log) the data received "from down below" (= from that background communication thread). This can very well be integrated with the software carl0s has written. I'll let you use my classes as if they were yours if you're interested, carl0s.
But apart from the fetching of the diagnostics data, I have the impression that everything else is available in this pheno's testo EDIABASLIB software ? To begin with, the translation(s) of the read values, their multiplication factors, etc. Has anyone here been using this testo software, more specifically this EDIABASLIB library ? I myself didn't install it on my computer yet, moreover I don't have the most probably necessary cables - even if I could simulate values coming in from over the network, but then again, I don't have any meaningful KWP2000- frames.
« Reply #34 on: January 06, 2018, 05:52:22 pm »
I'm partway there, sudolea.
I've tried running the 'standalone' testo program, which has the EDIABAS all included as a library (I think!).
Hardware
- cable(s) purchased
- plug identified (thanks TomL)
- device drivers downloaded & installed (it's a USB cable pretending to be an RS232 port)
- cable plugged in & red light comes on on the cable (haven't the faintest if red is good or bad - the Hong Kong seller isn't very helpful)
- however, the cable appears as COM9 when connected to the bike, which is positive (= device drivers working)
Software
I set Testo up to listen to COM9 - that's a setting in the .ini file:
[serial]
port=COM9
Start up testo standalone, and silence.
The major part of the menu seems to want to auto-detect the ECU, but nothing happens, other than errors.
Hmmm. And I can't seem to find any instructions on how to run it.
I can see a troubleshooting menu, and in there is the option to view the serial ports - COM 9 is showing up.
However, the troubleshooting options look very low level - pin level debugging.
So, I'm stuck on how to convince testo to take note of COM9, even though it's set to that in the .ini.
I guess there's some more setup needed.
So, the missing step, like I guessed a couple of months back, is:
> Sprinkle fairy dust  :D
This was over Xmas, and up the hill in a cold garage, so I gave up after a couple of attempts.
I'll have another read around, and see if I can find some testo instructions.
« Reply #35 on: January 06, 2018, 06:12:35 pm »
Correct me if I'm wrong but so far it doesn't seem to have been "Quick" or "Easy"  ???
« Reply #36 on: January 06, 2018, 06:26:10 pm »
Sometimes it worries me how stoopid you is  ::)
« Reply #37 on: January 06, 2018, 06:28:50 pm »
Moi? please clarify  :o
« Reply #38 on: January 06, 2018, 06:35:35 pm »
I mean, like, it is just so cheap and sooooo easy..... :o
« Reply #39 on: January 06, 2018, 06:45:56 pm »
But not quick  ;D
They have all been speaking in a foreign tongue for weeks.
« Reply #40 on: January 06, 2018, 06:56:44 pm »
But a GS-911 WiFi Enthusiast is less than £335!!!
« Reply #41 on: January 06, 2018, 07:31:42 pm »
Easy, yes. Buy a cable (wait 4 weeks for delivery from HK - Xmas got in the way) , download some software - plug cable into bike.
Quick, no. Not without accurate & complete instructions.
I'm just missing a few fairy dust steps.
Just found one that I missed, if anyone else is reading the thread, and considering trying specifically the 'standalone' version of Testo:
- Before running check EdiabasLib.config file and change your COM port, i.e. for me it should be
<add key="ObdComPort" value="COM9"/>
I'll give it another go tomorrow.
When I get it working, I'll write up the instructions for you, Rae, and we'll get you on a stopwatch.  ;D ;D ;D
Offline sudolea
« Reply #42 on: January 06, 2018, 07:37:32 pm »
Software
[serial]
port=COM9
If it's not caused by the setting in the second quote (which I think could very well solve it), it might be baud settings that could have to be modified ? 9600,8,N,1 is most probable; or is 10400 a possibility ? carl0s could probably help you better on this (I think he's on leave for the moment).
« Reply #43 on: January 06, 2018, 07:58:14 pm »
I have no need for this equipment Rich but thank you for thinking of me.  ;)
« Reply #44 on: January 06, 2018, 08:19:26 pm »
Demo day?
> Wednesday 6th [June]
9.00am      Set off from Market Harborough with a full tank please.
11.00am   Coffee stop at Rich’s place and demo Testo to Rae, just for the hell of it
If I've got it working by then  :-\
