Author Topic: Hello ... again  (Read 1020 times)
Ross Dean
Hello ... again
« on: November 11, 2017, 03:37:58 pm »
Hello All,
I was previously a member of this forum under the name Ross but its been so long since I posted that I had forgotten the login details.
I still have my 2010 K1300R which, as of October, is finally mine. The only issue with it until now was a rear shock failure but we sourced one on ebay which is now installed and running perfectly - it cost less than £100 plus p&p which was pretty good for a second hand BMW shock with esa - there is always a risk with second hand shocks but this one proved sound.
I have another issue with overheating in traffic which I'll search for first and post if necessary.
Ross
Re: Hello ... again
« Reply #1 on: November 11, 2017, 04:10:51 pm »
Hi Ross and welcome to the madhouse that is EuroKClub! Again!! I'm sure we have a feature that allows you to contact us to give you the account details....
Anyway, the overheating is, without a shadow of a doubt, a clogging/clogged radiator. This is a really useful feature of the K which gets you a new radiator every few years and it only costs about £450 a time.
The clogging is normally on the outside. The front, lower corners of the rad get full of shite because the front mudguard is rubbish for a sports tourer, more useful on a weekend warrior machine.
The solution is lots of soaking and gentle washing through from the back of the rad until you can see daylight through every pore in the matrix. Allow a whole day for getting it as clean as possible and hopefully the overheating will disappear.
Ross Dean
Re: Hello ... again
« Reply #2 on: November 11, 2017, 05:30:47 pm »
Hi Brian,
I guess to are right. I will check it out on Monday then start cleaning.
Ross
Offline Ross
    • Work website
  • Modifications and add-ons:: mirror extenders, tank protector, centre stand, larger BM screen, Garmin, BM luggage, rear rack, ... and factory fitted ASC, ESA, quick shifter
Re: Hello ... again
« Reply #3 on: November 12, 2017, 09:06:55 am »
And yet again!!!
I am now on the forum using my original name and profile.
Happiness is a bike and a tent
Re: Hello ... again
« Reply #4 on: November 12, 2017, 10:20:48 am »
Ain't tecnology wunnerfulll?
Offline Ross
    • Work website
Re: Hello ... again
« Reply #5 on: November 28, 2017, 02:27:27 pm »
Hi Brian,
Ross
Or ... not enough coolant ...
Re: Hello ... again
« Reply #6 on: November 28, 2017, 06:33:34 pm »
Could be. Modern vehicles tend not to use it the way older ones used to. I have never had to top up either the K12 or the K13 in 7 or 8 years of ownership and the 1150GS used nary a drop either  8)
Re: Hello ... again
« Reply #7 on: November 29, 2017, 12:57:41 am »
My R1150GS doesn't use any coolant either. ;)
Offline MadMountainbike
  • My K bike model:: K1200s
Re: Hello ... again
« Reply #8 on: November 29, 2017, 12:42:37 pm »
Funnily enough my old GS was the same, I put 120k on the clock and never a drop of coolant... brilliant  ;D
Offline Eyore
  • My K bike model:: K1200S
Re: Hello ... again
« Reply #9 on: November 29, 2017, 01:08:00 pm »
Marvellous the way BMW  have cracked all the cooling issues on their  air cooled engines, just wish their K12/13 systems were as reliable. ::)
Re: Hello ... again
« Reply #10 on: November 29, 2017, 02:13:54 pm »
Air and oil cooled.
Re: Hello ... again
« Reply #11 on: November 29, 2017, 04:48:59 pm »
But I doubt it would work for an across the frame 4 Tom  8)
Offline Ross
    • Work website
Re: Hello ... again
« Reply #12 on: December 20, 2017, 01:54:08 pm »
Right - problem solved.
The mechanic who solved the problem suggested that the people who did the last service replaced the coolant without using a vacuum pump. This resulted in an air lock which allowed coolant flow but there was too little coolant in the system. The coolant was replaced correctly and the bike is running correctly with no over heating.
Offline OxMan
  • My K bike model:: My 09 13S now being cherished by another man... dreaming of a 13R at some distant future point...
  • Modifications and add-ons:: 1 lucky new owner plus : Datatag; Helibars; BMW dustcaps(!); HID conversion (*2); Schrodie dual led running/indicator roundel lights; Zero Gravity screen; Rear hugger; Rear mudguard; Ilmberger carbon fibre bits (battery and tank covers; heel guards; fender extender); Sidestand big-foot; Frame cover; Smoked lenses; Brake/clutch fluid covers; Centre stand; numerous bungs...
Re: Hello ... again
« Reply #13 on: December 20, 2017, 02:36:19 pm »
That last service... independent or dealer...?
Late emerging biker - took the first bike plunge at 50 with a K1200GT : swapped for a K1300S 9 months in... addictive this biking lark!! 😎 Now had to sell the S... dreaming of a future day when I can return to the fold with a 13R.... Rrrrrrrr....
