Author Topic: Ilmberger hugger  (Read 2995 times)
Offline baldbiker
  • My K bike model:: K1300s
Ilmberger hugger
« on: August 25, 2017, 07:52:28 pm »
I had my tyre changed to the roadtec 01 on Wed and it is catching on the tyre on the right side worse than it did on the M3.
The hugger was second hand and advertised for k1300s is the any way to tell if it's for the 50 profile tyre.  I can't see a part number. Feeling peed off.
Re: Ilmberger hugger
« Reply #1 on: August 26, 2017, 09:47:10 am »
If it was for a 1200 bike it's narrower so need to trim it.
Offline baldbiker
« Reply #2 on: August 26, 2017, 01:21:24 pm »
Has anyone got a measurement from edge to edge please. It seems to be in one area, it's coming of later to check properly.
Offline baldbiker
« Reply #3 on: August 26, 2017, 03:49:45 pm »
The only numbers I can find are.  100351Q and another which I presume is from a post production check..
Offline Mikek7
  • Modifications and add-ons:: none ... yet
« Reply #4 on: August 27, 2017, 11:14:48 am »
I also have an Ilmberger hugger and Roadtec 01s on a K1300S - no clearance problems.
There is approx 10mm clearance on each side. Bit difficult to get an accurate measurement without taking it off, but it seems to be 205mm.
Left and right pictures here ... and yes, its dirty after this mornings ride :)
https://goo.gl/photos/GRgXn9d9f3Phz2PX8
https://goo.gl/photos/uPtKa55BQt4Pf9Pz7
« Last Edit: August 27, 2017, 11:34:20 am by Mikek7 »
Offline baldbiker
« Reply #5 on: August 27, 2017, 01:15:55 pm »
Thanks for those . It seem to be catching at the top to the right of centre.
Offline baldbiker
« Reply #6 on: September 07, 2017, 06:12:28 pm »
I've contacted ilmberger last week with the numbers I had and they have promptly replied bit with no real answer as yet.
Would spacing the hugger to bring it to the right a few mm help.
