Author Topic: When is a Full Main Agent History -NOT ?  (Read 2890 times)
Re: When is a Full Main Agent History -NOT ?
« Reply #15 on: May 11, 2017, 11:58:16 am »
As an aside, I find it best to check the coolant level at night, a dark garage would do, if I had one!
If you remove the coolant bottle cap and shine a light into the orifice, the level shows up much better than trying to do it in daylight.
Offline Graham55
  • My K bike model:: K1200S 2005
  • Modifications and add-ons:: BMW LAZER optional silencer
« Reply #16 on: May 11, 2017, 01:30:32 pm »
Now we seem to have got into coolant issues, can anyone tell me if there is a ( relatively easy ) method of changing the coolant without special equipment to refill, so that you can be sure there are no air locks - I assume this is why BMW use special equipment- or say they do in the manual.
« Reply #17 on: May 11, 2017, 02:56:56 pm »
It needs to be vacuum filled, kits are available on Ebay.
« Reply #18 on: May 11, 2017, 03:15:31 pm »
Offline Graham55
« Reply #19 on: May 12, 2017, 08:45:41 am »
It is an early k1200s and does have the bleed nipple. For safety it is a vacuum kit then I guess.
« Reply #20 on: May 12, 2017, 09:25:06 am »
Now would be a good time to include your Model and year in your profile Graham, this demonstrates why  ;D ;)
« Reply #22 on: May 13, 2017, 10:54:42 am »
Very neat kit, being designed 'flat'. Mine is a clumsy three dimensional thing which is in a 'huge' box.
If you haven't hit the 'buy' button yet, one caution is that you need a small (conical?) adaptor for the radiator cap orifice.
A lot of car kits don't have the small adaptor!
« Reply #23 on: May 14, 2017, 10:47:07 am »
I'm not buying one just yet, I still need to get my radiator dirty and then time to fall apart before replacement and then refill
« Reply #24 on: May 14, 2017, 06:01:30 pm »
I'd order it now! By the time it arrrives, you'll need it  :o
« Reply #25 on: May 16, 2017, 03:42:42 pm »
Nice kit and in a very convenient price.
