Author Topic: battery charger  (Read 2408 times)
Offline markyates
  • My K bike model:: 2009 K1300S, black/silver
  • Modifications and add-ons:: BMW rack, titanium Remus Hexacone, sport panniers, Ilmberger hugger, carbon front mudguard
Re: battery charger
« Reply #15 on: July 10, 2016, 06:45:54 pm »
Are those of you with the Optimate using the canbus version (Optimate 4?) but set to standard? Does the canbus/DIN work OK? I need to get a new charger and would like to have the options....
Or the (expensive) BMW one?
Cheers
Mark
Offline CC Mac
Re: battery charger
« Reply #16 on: July 10, 2016, 10:16:21 pm »
Optimate through the power socket, no problems.
Watchin you Focker
Re: battery charger
« Reply #17 on: July 10, 2016, 10:52:33 pm »
It doesn't work with mine .  Had to connect battery directly.
Offline markyates
Re: battery charger
« Reply #18 on: July 10, 2016, 11:19:22 pm »
OK thanks.
Think I'll try it with canbus and see how it goes....
Re: battery charger
« Reply #19 on: July 11, 2016, 12:12:01 pm »
Optimate 4 directly across battery, don't trust can'tbus!
Offline markyates
Re: battery charger
« Reply #20 on: July 12, 2016, 04:45:40 pm »
Thanks to everyone.
Think I'll get the Optimate canbus kit then I have both options...
Offline baldbiker
  • My K bike model:: K1300s
Re: battery charger
« Reply #21 on: July 21, 2016, 09:52:05 pm »
Having just got my new k can I confirm from this conversation that charging the battery using normal optimate cables fixed to the battery is ok and when the leads on the battery are removed to fit said optimate leads do I loose any info on the dash.
Re: battery charger
« Reply #22 on: July 21, 2016, 11:43:34 pm »
You'll probably lose the trip data and average consumption stuff but I have fitted and un-fitted the cables many times and have mostly never lost anything because I press down on the battery cables as I remove the bolt, slip the bolt through the new jumper cable and refit it without losing contact on the battery cables. Fiddly but possible if you plan and prepare properly!
If you do manage to disconnect totally then you may need to reset the throttle position sensor afterwards. Ignition on but engine OFF, turn throttle twistgrip slowly to fully open position, hold there for a couple of seconds, close throttle, repeat twice, ignition off, job done.
Brian (who says it's only 12volts but it can still bite so use a firm hand, or at least finger  8) )
Offline Greenman
  • My K bike model:: A 2009 my 1300s (maybe the sport model as it has all the options)
  • Modifications and add-ons:: Zumo 550, optimate, rear rack, tail packs, panniers, front and rear R&G axle protectors.
Re: battery charger
« Reply #23 on: July 22, 2016, 07:10:00 am »
 I've had my battery disconnected for several minutes without losing any data so I think you'll be ok.
Offline lanerider
  • My K bike model:: k1300r
  • Modifications and add-ons:: All sorts added on and still adding on and on cant see me stopping
Re: battery charger
« Reply #24 on: July 22, 2016, 07:48:22 am »
i have optimate 4 with bmw plug in socket and it works fine  8)
lanerider
Offline peterwbaker
Re: battery charger
« Reply #25 on: January 06, 2019, 07:47:16 pm »
I see the consensus is to direct connect:-) however has anyone brought one of those expensive :-) BMW chargers and used it via the Canbus socket with success?  Peter
Re: battery charger
« Reply #26 on: January 06, 2019, 08:09:45 pm »
I have one secondhand BMW charger, but use it direct onto the battery terminals, through habit. (My last bike didn't seem to want to charge via the canbus, and I forgot to try it direct on the newer bike.) It works well and it's all of 1 minute to remove the cover.
I'm happy to try via canbus if you need to know.
Offline Swindon Andy
  • Modifications and add-ons:: Helibars, clear front indicators, LED rear indicators, TomTom mount, Ilmberger hugger, HID dip
Re: battery charger
« Reply #27 on: January 06, 2019, 11:16:37 pm »
Same here, works just fine provided you set the Optimate 4 to canbus mode.
Re: battery charger
« Reply #28 on: January 07, 2019, 02:10:28 pm »
No cambus setting on mine. Just tried it out.
First on a spare battery using the crocodile clips
then on my VFR battery on the bike, again using the clips
then my K13s using the socket on the bike.
All worked without changing anything as the charger recognises the different systems.
Re: battery charger
« Reply #29 on: January 08, 2019, 12:07:59 am »
Mine says you have to connect both pos and neg terminals together (on the charger, NOT the battery  8) ) then turn it on to switch between canbus and direct mode.
