Author Topic: battery charger  (Read 2227 times)
Offline Kev Meers
battery charger
« on: June 12, 2016, 01:21:08 pm »
Hello,
does anyone know if its possible to get an extension lead for a canbus connector.  I have a BMW battery charger but the leads are a little short.
thanks
kev
Re: battery charger
« Reply #1 on: June 12, 2016, 01:24:50 pm »
Take a look at touratech and wunderlich catalogues. Nippy Normans is also a reliable and closer source.
Re: battery charger
« Reply #2 on: June 12, 2016, 01:40:07 pm »
Cut the wires and solder splice a section in.
Re: battery charger
« Reply #3 on: June 12, 2016, 01:47:01 pm »
Don't use it on the canbus, use it across the battery (assuming BM haven't outlawed that setting!).
Either way, try Elite Motorcycles ( http://elitemotorcycleservices.co.uk/index.asp?optiacc.html ). They do all the accessories for Optimate including extension leads if you can't solder!
Offline Kev Meers
Re: battery charger
« Reply #4 on: June 12, 2016, 02:46:22 pm »
Thank you all
Offline bobtail
  • My K bike model:: K1200S (05) departed but well loved! Now R1200RS I am now a Boxerboy.
  • Modifications and add-ons:: I had no bling on my K12 and was proud of it! And it never, ever let me down, honest! And it still had the o.e. battery going strong, honest!
Re: battery charger
« Reply #5 on: June 12, 2016, 03:25:03 pm »
Mr Optimate is the way to go and direct to the battery. Looked after my OE battery in the K12 for over 10 yes that's right TEN years!!!! I believe I hold the record for that should it be in the Guiness Book of Records?
Bob
Are we there yet? I said ARE WE THERE YET? I SAID ARE WE THERE YET?!!
Re: battery charger
« Reply #6 on: June 12, 2016, 03:27:00 pm »
It sure goes for the record.  ::)
Re: battery charger
« Reply #7 on: June 12, 2016, 03:54:47 pm »
The one in my 12 is at least 5 years old and perhaps even 6 and stronger than the one in my 3 year old 13 thanks to the Optimate. None of this nonsense about the Canbus connector just a short lead to the battery which serves for charging and for getting power out to the tankbag for mobile phone charging, powering the camera etc!
Offline fjtwelve
  • My K bike model:: Night Black K1200S 2008
  • Modifications and add-ons:: Low seat, Akrapovic carbon can, BSD remap, Pazzo levers, slate grey wheels
  • Location:: Falmouth, or Schiphol, depending which day of the week it is
Re: battery charger
« Reply #8 on: June 12, 2016, 06:26:37 pm »
Bob
My battery as far as I can tell is original and is celebrating its 8th birthday next month. Never been near a charger
« Last Edit: June 12, 2016, 08:54:20 pm by fjtwelve »
Re: battery charger
« Reply #9 on: June 12, 2016, 08:43:47 pm »
I have a standard car power point attached to my battery, then use one of these http://www.jenelec.com/products/unicharge-range on a male plug
Re: battery charger
« Reply #10 on: June 13, 2016, 07:13:47 am »
All you lucky ones with the previous to 2009 batteries. :P
Offline Kev Meers
Re: battery charger
« Reply #11 on: June 15, 2016, 07:26:35 pm »
With your optimate do you connect straight to the battey terminals or coonect through the dinsocket .?
Thanks
Re: battery charger
« Reply #12 on: June 15, 2016, 08:30:40 pm »
Sod the socket; way too finicky, especially if you have a second battery you want to keep topped up as you have to keep changing modes!
I use the Optimate battery connector lead connected straight across the battery and this 'input socket' also serves as an 'output socket' to power my camera or the phone charger in my tank bag.
Offline Kev Meers
Re: battery charger
« Reply #13 on: June 16, 2016, 06:18:05 pm »
I'm going to stick with my accumate direct to the battery I reckon, thanks for all the replies.
cheers
Re: battery charger
« Reply #14 on: June 16, 2016, 06:36:48 pm »
Wise choice from my perspective  8)
