Author Topic: Brake pads  (Read 5392 times)
Re: Brake pads
« Reply #30 on: August 29, 2016, 10:04:56 am »
It appears that best brrake pad configuration after all kind of reports is oem front and carbon llraine rear. K1300s bikes.
Offline AndyLP
  • My K bike model:: K1200S
Re: Brake pads
« Reply #31 on: September 02, 2016, 01:07:02 pm »
Where do you order the Lorraine pads from?
Re: Brake pads
« Reply #32 on: September 02, 2016, 03:46:13 pm »
CL are availiable there am sure , try: carbonelorrainebraking.uk
Offline TurboBevy
Re: Brake pads
« Reply #33 on: June 14, 2018, 05:36:15 pm »
To my shame, I ran the rear pads down to beyond the friction material while on tour around Engerland & Welsh Wales last month. 1150 miles in 7 days. I could hear the rear pads making metal to metal contact (ouch) while on route to Fishguard. Our next stop was Chester, so booked the bike into Chester BMW for the next afternoon and had little option to continue using as little brakes as possible.....
Long & short of it was, new pads and disc fitted while I waited. £310. Problem solved but having to replace the disc at just 16k was a bit extravagent and no-ones fault but my own.  :-[
Bike was in for its second MOT last week at Cupar Motorcycles and passed with just one advisory for yes you guessed it. Front pads are worn. Keen for history not to repeat itself, I've ordered and received today a set of these bad boys. Will squeeze them in over the weekend.  8)
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/403061
Also had a split new pair of Michelin Road 5s fitted pre MOT as the OE Metzlers were shagged in just 4000 miles. Man new tyres are things of joy, the bike rolls into bends like it used to rather than having to be urged to do so. Very early days with the Road 5s but they look and feel the business.
Cheers, TB.
« Last Edit: June 14, 2018, 05:48:38 pm by TurboBevy »
Re: Brake pads
« Reply #34 on: June 14, 2018, 05:45:47 pm »
Wow. 4k. That's bad. You're not rubbing the brake pads on the tyres, or something weird, are you?  :o
Just in interest, what's your MPG?
So we can work out if you're a messiah with a dodgy bike. Or just a naughty boy.
(To paraphrase TomL(?):  Anyone getting more than 54mpg is an idiot, anyone getting less than 46mpg is a maniac.)
« Last Edit: June 14, 2018, 05:51:46 pm by richtea »
Offline TurboBevy
Re: Brake pads
« Reply #35 on: June 14, 2018, 05:55:21 pm »
To paraphrase Tom(?):
Anyone getting more than 52mpg is an idiot, anyone getting less than 46mpg is a maniac.
To be fair. The front had some life left, the rear was on the TWI. I always change them as pairs as this is no scooter.
Avg MPG is around 45, which I thought was good. Certainly better than the 27mpg my GTi returns.
I only ever used to get around 3k from a rear of the VFR and the Versys. Michelin Road 4 were much better on the Versys, I got around 6k on those. High hopes that the Road 5 will return a more reasonable 5k?
Cheers.
Re: Brake pads
« Reply #36 on: June 14, 2018, 06:04:56 pm »
Hope you said hello to Steve Parry while you were in Chester  ;)
Re: Brake pads
« Reply #37 on: June 14, 2018, 06:19:59 pm »
I'd expect 7-8k with modern tyres.
However, I think you're hooning around a bit quicker than me since my MPG is 49-50 - that's mixed countryside & village/town.
It was 52.5 on the Wrinklies, but then again, you progress a little bit more carefully as a group, if you're not right at the back  :D
Offline S BMW
Re: Brake pads
« Reply #38 on: June 14, 2018, 08:31:55 pm »
Howdie All,
it so happens mine are up for replacement shortly so what is the recommendation always used EBC so now think oem front and brembo red rear sintered.a good choice ?
Re: Brake pads
« Reply #39 on: June 14, 2018, 08:36:18 pm »
I believe the general consensus it that OEM are best. Expensive but best. You will only get the wear sensors with OEM.
Re: Brake pads
« Reply #40 on: June 14, 2018, 11:14:39 pm »
No wear sensors on the K1300S.
Re: Brake pads
« Reply #41 on: June 15, 2018, 08:55:56 am »
Right Tom, I wasn't sure, just though it was worth a mention. The wear sensors were rubbish anyway  ;)
Offline TurboBevy
Re: Brake pads
« Reply #42 on: June 16, 2018, 02:12:22 pm »
Fair play. Brembo pads are more easily sourced and with the OEM only returning some 4000 miles, WTF. I've gone with these Brembos in the hope they'll be as good and last that wee bit longer? I've also got another trip booked for the Western Isles, for mid-July, before the bike will go in for its first 18k service in early August. The front pads however need changing now.  I knew this before I bought it, but these bikes are not cheap to run, service, own.
Re: Brake pads
« Reply #43 on: June 16, 2018, 02:26:21 pm »
Was 4000 miles a typo, I got 40,000 plus from my OEM front brake pads
Re: Brake pads
« Reply #44 on: June 16, 2018, 02:46:06 pm »
4k for pads as well as tyres?
If BMW are servicing it, I'd ask them if there's a fault. It doesn't feel right.
I had a pad change at 18k, and another at 31k (= 13k pad life). The first 8k were ridden by someone else, so I think I may be a heavy user. Which makes sense since I'm a heavy person.
