Author Topic: Re keying panniers  (Read 1415 times)
Offline lanerider
  • My K bike model:: k1300r
  • Modifications and add-ons:: All sorts added on and still adding on and on cant see me stopping
Re keying panniers
« on: October 29, 2015, 06:45:45 pm »
I now have a set of bmw sport panniers that need re keying is it easy to do and how do i do it thank you  :-\
lanerider
Re: Re keying panniers
« Reply #1 on: October 29, 2015, 07:28:08 pm »
There are threads and videos on re-keying a top box but I haven't seen anything on pannier re-keying. It may well be the same as the top box but I'm not sure.
« Reply #2 on: October 29, 2015, 08:27:05 pm »
I've done it and it is not difficult to do.
http://www.bmwmotorsports.org/k12s/locks/locks.html
« Reply #3 on: October 29, 2015, 09:05:25 pm »
Nice find Tom.
« Reply #4 on: October 29, 2015, 10:55:37 pm »
Don't forget that if you decide to sell your bike and want to keep the panniers then you need to take the lock barrels out and leave them out until they are matched to the new bike keys.
Before you take the key out of the barrel run some tape around the outside unless you want lots of loose springs and levers. If need be the odd lever can be left out if you don't have the correct levers to choose from. Not so secure but who would know.
  • Global Moderator
« Reply #5 on: November 06, 2015, 11:10:47 am »
Thanks for the link.  I've just taken my barrel out, it was surprisingly easy to do after a bit of prodding.  Total 9 screws removed and five minutes effort.
Unfortunately that guy links to two external sites for the rekeying... which are both dead now :(.  I'll update this thread as and when I find a more alive one.
I'll also take photos if I remember and see about making my own tutorial (read: I'll probably forget this step and drink beer instead).
Edit: or just look here:
http://www.mototrip-tours.com/blog/workshop/rekeying-bmw-case-locks/
« Last Edit: November 06, 2015, 11:14:23 am by Matt »
« Reply #6 on: November 06, 2015, 12:15:07 pm »
Basically when the key is inserted in the cylinder, as shown in this photo, then the correct lever will not protrude.
  • Global Moderator
« Reply #7 on: November 06, 2015, 12:18:04 pm »
Hey,
Yep I've got the barrels out for both panniers now.  My only problem is that when I remove the key the tumblers just stay in.  I've tried pulling them out with needle nose pliers to no avail.
Everything I read says they'll spring out!
  • Global Moderator
« Reply #8 on: November 06, 2015, 12:23:45 pm »
Hm, the end posts of this thread implies the barrels changed.  Mine is the one with the chrome end cap on and presumably the brass rod holding the pins in.
This might take a while to remove, it's crimped on.
http://www.i-bmw.com/showthread.php?t=33292
« Last Edit: November 06, 2015, 12:34:54 pm by Matt »
« Reply #9 on: November 06, 2015, 02:39:28 pm »
Not seen that. Mine is the type without a retaining rod.
« Reply #10 on: November 07, 2015, 09:39:05 am »
Sounds like a money-making scheme to me.
Brian (who says 'take it to the dealers, they'll probably do t for nowt'  :o )
  • Global Moderator
« Reply #11 on: November 08, 2015, 09:53:10 pm »
Well after a bit of hitting it with a hammer and driving stuff between the edge of the chrome cap and the lock proper I managed to pop it off.  There's a thin rod that when removed allows everything to pop out.
Now I'm just leaving both lock barrels and everything laid out waiting for the arrival of the new key to code them to!
Offline Belco100
  • My K bike model:: K16GT & S1000XR
« Reply #12 on: April 09, 2018, 06:55:20 pm »
Argh - its gone! Trying to remove the locks but  :-X :-X :-X :-X :-X
