Good Afternoon Forum Knowledgeables !
I collected my 1300S and knew when I purchased it, that it had a cradle mounted for a Navigator (not sure which version) - but no navigator.
It is fixed on the battery cover and whoever fitted it decided to drill a nice circular cut out (3cm in diameter) in the cover and then fit screws through the cover also.
My plan to remove the navigator and replace the panel took a bit of a knock this morning given a replacement battery cover seems to run at between 95 and 180 of my finest quids.
I wondered if it was possible therefore to remove the navigator mount and maintain the "sub-mount" (the bit that is actually fixed through the battery cover) and use it to connect to a mobile phone mount. I can then attach my phone and use googly maps etc etc.
Anyone trodden this path before ?
Many thanks
Andy
