Author Topic: Rear suspension link bearings  (Read 343 times)
Offline Eastsussexbiker
« on: March 02, 2024, 03:37:00 pm »
Cam gasket leak sorted I moved on to rear suspension link bearings.  Curiosity killed the cat !! However once again Bodgit and Scarper have been paid to put there incompetent hands on another repair.
Just 1 of the needle rollers has failed and found to be seized but with a bit of heat and a drift it came out. The bush will go again but the needle roller is toast.
Part’s sourced from simplybearings.co.uk. Cheaper than Motorworks and a main dealer.
« Last Edit: March 02, 2024, 04:06:49 pm by Eastsussexbiker »
Re: Rear suspension link bearings
« Reply #1 on: March 02, 2024, 03:59:20 pm »
« Last Edit: March 02, 2024, 04:05:46 pm by Eastsussexbiker »
« Reply #2 on: March 02, 2024, 06:13:09 pm »
Looks fun! Forgive my ignorance but what shows that one of these is toast? Is it when you fiddle with it and find it not moving? Or is it a visual inspection of something having failed?
« Reply #3 on: March 03, 2024, 04:15:31 pm »
Take it apart and it will be obvious if it needs replacing.
After cleaning and greasing, fit the pivot pin and it should rotate freely and smoothly.
