Author Topic: Cam Cover Leak  (Read 1932 times)
Offline Eastsussexbiker
Re: Mod to Cam Chain guide
« Reply #30 on: February 27, 2024, 07:09:19 pm »
Well I finally bit the bullet and shaved 2-3mm off the cam chain guide to prevent the oil leak from cam cover I haven’t tried it yet as only managed to refit cover tonight. Hope to fit radiator later this week. I was a bit limited as to what I could use to do this but it was worth a try.
check duplicate online
« Last Edit: February 27, 2024, 07:11:34 pm by Eastsussexbiker »
Re: Cam Cover Leak
« Reply #31 on: February 29, 2024, 01:53:54 pm »
All sorted now and cooling system bled.  It was the cam chain guide being too long. Shaving some of it 2-3mm sorted it out and gasket sit nicely and flush and no leak.
What next !
Re: Cam Cover Leak
« Reply #32 on: February 29, 2024, 01:58:12 pm »
Great result well done and thank you for keeping us informed.
Re: Cam Cover Leak
« Reply #33 on: February 29, 2024, 06:45:30 pm »
Agreed, but what a cock-up by BMW, coming up with a cure for the dreaded camchain jump (caused by a design fault meaning the chain went slack on start up in the first place due to the tensioner losing oil, mainly when sat on the sidestand) which then causes the guide to sit too high causing seal damage and an oil leak.
Having never had reason to dive into the clutch on the K13 (that's doomed me), I always thought that the jump guard was only a K12 sticking plaster. Mine had it fitted by Bahnstormer along with the later, taller, tensioner.
So do all K13's have the jump guard fitted as standard?
Re: Cam Cover Leak
« Reply #34 on: February 29, 2024, 11:42:59 pm »
From 2012 I believe
Re: Cam Cover Leak
« Reply #35 on: March 01, 2024, 08:59:17 pm »
2012. Well, that was when it was retrofitted to my K12S, so I guess we all have them lurking in the bowels with chain guides just waiting to nerf the cam cover gasket, like when mine goes in for its 18,000 service... :winkthumbs:
Re: Cam Cover Leak
« Reply #36 on: March 01, 2024, 09:39:15 pm »
At least you know what to do about it.
Re: Cam Cover Leak
« Reply #37 on: March 02, 2024, 08:48:58 am »
Not do the service?
Re: Cam Cover Leak
« Reply #38 on: March 02, 2024, 09:07:54 am »
It’s refit fairing day today then on to service rear suspension link assy. Although I might do that first ! Then rear driveshaft regrease
Re: Cam Cover Leak contd
« Reply #39 on: March 26, 2024, 03:24:07 pm »
Saga continues
Just shaved more of the chain guide so is flush with the top of the head.  All back together now and water added but have not started it yet.  I wanted to check the breather pipes. Found they had mayonnaise in them but not excessive.
Has anyone actually had the two hoses block up what did you do?  What was the symptoms.
« Last Edit: March 26, 2024, 03:25:38 pm by Eastsussexbiker »
Re: Cam Cover Leak
« Reply #40 on: March 27, 2024, 09:40:08 pm »
Looks like a coronary artery blockage. Get 'em off and give them a good clean I'm guessing.
Re: Cam Cover Leak
« Reply #41 on: March 27, 2024, 09:45:02 pm »
I’m going have a go tomorrow awkward to get off.  I may start it with them off and see what pressure there is.
