If you haven't introduced yourself in the 'Who's Who' section, please do!
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
Home
Help
Login
Register
EuroKClub
General forum area
K1200 / K1300 Forum
1300 r front shock
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1300 r front shock (Read 1469 times)
geg1961
Jr. Member
My K bike model:: k1300r
1300 r front shock
on:
March 04, 2017, 08:49:22 pm »
Ok chaps, k1300 r non esa , front suspension, the front shock is threaded at the bottom, can i use this to adjust the front ride hight?
Logged
Costas
Hero Member
Riders drive K, a Hawk flies, both are fast
My K bike model:: K1300S
Modifications and add-ons:: BMW Motorrad rider and pillion HP4 pegs,10-30 lit tank bag, SENA for BMW intercom system. Evo air filters. TechSpec tank pads. MIZU lowering dogbone system. B2 accelerator. Wunderlich adjustable levers, hub , brake caliber protectors, duolever bold protector. Turatech ABS Sensor protectors. IDE bars. Rizoma rear led signal lights, bar ends with lever protectors. Sargent complete system seat (pod, pillion backrest). Shrodie side badge led signal lights two modes. LED lights 2X35W 3000k high beam, 10W parking two modes. Tracker. Metisse front wheel protector sliders. R&G water pump protector, cardan protector. Ilmberger carbon set. Ztechnic tank protector,DT wimglets.
Location:: Athens, Greece, KS-Loutsa 37°58'16.6"N 23°59'06.8"E 37.971269, 23.985224
Re: 1300 r front shock
Reply #1 on:
March 05, 2017, 04:36:59 pm »
Yes but any adjustement needs ro be done to the rear too.
Logged
geg1961
Jr. Member
Reply #2 on:
March 05, 2017, 05:19:09 pm »
Thanks Costas, i'v dropped the rear by 25mm should the front be lowered by the same amount?
Logged
Costas
Hero Member
Reply #3 on:
March 07, 2017, 07:17:54 am »
That cannot be answered verbally , need to sit in bike and follow certain steps. A utube video fm CSS school instructor and founder keith Code is availiable for this short of adjustements.
Did you lowered the rear by using a dog bone lower plate? Or with new shorter but harder springs? In case one nothing is needed as the hole bike in now sitting lower and no adjustements are needed. If it's case two then yes adjustement both for front and back are needed.
Logged
geg1961
Jr. Member
Reply #4 on:
March 07, 2017, 07:32:47 am »
Yes i used the lowering plates, so all ok then?
Logged
Costas
Hero Member
Reply #5 on:
March 07, 2017, 08:15:49 am »
Great news, thought about it since I too replaced it in order to acomodate my boots and step firmly on the ground.
Then all are OK you can proceed without any other adjustement needed.
Need to restrain yourself and not over adjust it , try two threads at the time and give it at list two days of riding before going back to correct it. It's hard with those systems and needs a lot of work.
Logged
Print
Pages: [
1
Go Up
« previous
next »
EuroKClub
General forum area
K1200 / K1300 Forum
1300 r front shock
