Hi All
If there is anyone left watching the thread, I have now managed to get a couple of the many photos loaded. More if anyone want to see.
Re-cap
K2008GT Transmission 2nd gear has been unusable for last 34k miles due to it bouncing out under load. Never fixed it as most of my commute is easily coped with as a 1st to 3rd shift - but it is a major issue once you use the bike for its real purpose - touring around biking roads.
Transmission was pulled and sent off to get the all but 1st engagement dogs machined and any other repairs (score marks, shifting forks. seals, etc.)
Whilst that was ongoing, it was a good time to do "stuff" given the bikes 57k miles so
Clutch change out, cam chain, cam sprocket, tensioners, runners and retainers all changed/ added.
Clearances checked (will need to go back in and close up the exhaust clearances soon), plugs changed, cooling fluid replaced, SLS valve reconnected, final drive oil & paste renewed, oil pump chain replaced, brake & clutch fluids flushed & replaced, fuel tank quick connect & hose replaced, fuel tank activated charcoal filter removed, all gaskets disturbed were replace (including the 18 bolts that hold on the clutch cover) plus some other minor "bits".
Bike tested on center stand and road tested - all running great - very minor oil leak on from rhs of cam cover gasket which is only there when on center stand (not side stand - I can live with that)
Appreciate all your inputs and support - now looking to see what fails next - suspect the electronic suspension must be due for a failure!
Some pictures below - Tom McC
1 Engagement Dogs Prior to Machining - I somehow lost the pictures of the final cuts, but it was a very subtle angle which makes the dogs "grab" the gear as opposed to slide in & out easily.
2 2nd Gear face damage - note the scored face on the middle - 2nd gear - in picture where shifter fork operates)
3 Damaged 2nd gear fork - none of the other forks were in similar condition, but the second gear "popping" did cause very minor teeth damage and other bits & pieces.
4 First Friction Plate - side running on basket Face - Hmm, another month and it would have been a replacement clutch package @ $1300.
5 First Friction Plate - side not running against Basket Face (note that all the other friction plates look good, but the amount of friction pad sludge probably from that first plate) was very high. The whole compartment required a good clean down. Emphasises the importance of oil/ filter changes.
6 Original Laminar Package with Green Bands
7 Clutch Cage Tab wear - another well documented issue whereas the tabs evenually wear the cage and over time make plate movement difficult.
8 Barnett Clutch showing tab orientation one way and one way only I found - tabs with notch, which is not in the center of the tab, must have the notch lesser side in the ACW orientations
