Costas, TomL - Thanks for the input - valuble
TomL - you would think, but slipping that chain back down past the sprocket nut (easy) and onto the sprocket (impossible) turns into one of these chinese puzzles where things have to lined up, move exactly, twist, turned etc. I spent at least 4-5yrs attempting - I have long slender fingers and relatively smail hands - I could get the fingers down past the sprocket bolt, but that was the end of it.
So Friday evening it was off with the manifold, sump - the only hitch was trying to unplug the Oxy sensor and the sump residual oil/ gunk. Looking back, 15mins to get the sump off and a bit of clean up is much easier - I'll see how that manifold goes back on and how many oil leaks we get from disturbing the sump. The chain went on immediately it was out of the way. This also gives the opportunity to clean up 9yrs of sump gunge - no doubt most of it from clutch dust.
Ok had to call him at home , no issues he's is babysitting , so the answer is 0,4cm .
I had actually installed the chain on Friday and had the clutch cage/ basket installed, but the oil chain tension was bothering me a bit - but that's the proper tool and the official procedure therefore it must be right ........ but I note that they don't provide a qualitative figure to check against.
When following the procedure in RepROM, the chain slack with ECCENTRIC GAUGE tool in place was around 6mm, with the tool removed and the collar back in place this gave slack of 9mm - obviously too slack - you can tell just by feeling the amount of slack.
I checked the eccentricity of the tool, this gave the material thickness of the tool at the said mark as 5.7mm, and the opposite side material thickness of 5.5mm - I suspect these the 0.2mm offset provided by the tool (if I do the math - which I won't) will not give the necessary setting.
So Costas, your 4mm figure confirmed the concerns and I took the clutch and stuff back off this evening and reset it by feel and whoa and behold it was around 4-6mm when finished.
So oil chain completed, timing chain with all its anti-jump devices fitted and clutch installed. I'm using a Barnett clutch. Interestingly they have one of the tabs on each friction plates notched on their edges to align and insert into the proper orientation into the cage - there is one complexity which I didn't see in their literature - the notches are biased to one side of the tab - unless this biased side is place on the CCW side of the pack, the clutch basket will not fit into the assigned clutch cage position.
I'll try and get this all wrapped up Sunday/ Monday - I can maybe post some of the pictures of the various failures and repairs - particularly the transmission changes. I need to get this thing back on the road before the heat is turned up and enjoy our winter/ spring conditions.
Thanks Again - Tom
