Did you do the level checks iaw the manual? Saying it was above max before you set off suggests not before the ride. Saying you checked it 15 minutes after you got back suggests you didn't do it iaw the manual then either.
I doubt anyone can help until we know the level is checked iaw the manual. If you check it iaw the manual and the level is too high, do what it says in the manual to correct the level, it really isn't rocket science.
If you correct the level and it keeps going up, you have a problem.
If you correct the level and it doesn't, when checked iaw the manual, then you have no problem.
To help us, the following would be useful...
Who did the last oil service?
When was the last oil service in terms of miles?
Have you ever done the oil check iaw the manual?
If so, what was the level?
If you have never done the check iaw the manual, why not?
If never, what have you got against the manufacturer's recommended method?
