Author Topic: K1300 GT Oil Level Warning  (Read 661 times)
Offline Nin
  • My K bike model:: Will be a 1300GT soon
« on: February 17, 2024, 10:17:50 am »
Hi all, long time lurker, first time poster!
I have a 2009 K1300GT.  It’s had a full BMW service history up to the point I got it last year. So will have had all the recalls done (none are showing as outstanding) so I assume it’s also had the stalling software upgrade done too.
That’s relevant because of the link to the problem I’m seeing - which is the ‘<!>’ Oil warning I’m getting on the dash.  Some suggest it’s a software glitch linked to the upgrade.  GS911 reports a fault with oil level, possibly over filled.
Obvs I’ve checked oil level using the dipstick and correct method for dry sump bike - it’s bang on the ‘Max’ line.
Question is, has anyone found a fix?  I read of multiple bespoke software updates still not fixing it, and tbh I can live with it.
All advice welcome!
Nin
« Last Edit: February 17, 2024, 04:48:33 pm by Nin »
Re: K1300 GT Oil Level Warning
« Reply #1 on: February 17, 2024, 04:11:33 pm »
The "Hot Start" was not software problem.
« Reply #2 on: February 17, 2024, 05:22:33 pm »
Welcome Nin.
The 'hot start' (aka stalling) fix is a physical one - it's an extra loom to help deliver more current from the battery.
The oil level is measured when the engine is hot and the bike is on the centre / held vertically.
If you looked at it whilst cold and/or on the side stand it may well be too high when the engine gets hot.
Offline Nin
« Reply #3 on: February 17, 2024, 06:26:03 pm »
Thanks for your replies, I got my hot starts and stalling mixed up in the first post - now corrected.
Anyway - I understood the stalling issue was resolved by a software update.
I’ve read that software update causes the oil level sensor to give a false <!> ‘Oil level’ warning.
I’m getting that warning.
The oil level is spot on the ‘Max’ point in the dipstick, when measured as per the owners manual. (Hot bike, on centre stand, dipstick screwed out and resting on threads).
Is there a known fix to stop this false error?
I’m guessing not …
« Reply #4 on: February 17, 2024, 08:11:10 pm »
Ah, good. :thumbsupgood:
A suggestion from the rider manual:
Possible cause:
The oil sensor might be defective if the "Check oil level" message appears even though a check of the oil sight glass shows that the oil level is correct. Seek the advice of a specialist workshop, preferably an authorised BMW Motorrad dealer.
I'm not sure the GS-911 would report that - but you would hope so, and yours hasn't.
Offline GlynH
« Reply #5 on: February 18, 2024, 11:41:22 am »
Well I’ve never had anything other than the normal OK for oil when coming to a standstill at traffic lights for example.
The GS911 should enable you to see the I-Level version of the bike and also that of the various modules so you can check to see if any software might deviate from factory?
In my case the GS911 returns the following;
I-Level factory
K024-10-02-550
I-Level previous
K024-10-02-550
I-Level actual
K024-10-02-550
Showing it has never been updated despite being purchased and having every recall & service carried out by the same dealer on schedule. Well apart from the latest one that was due last week!
I understand in most cases BMW Dealers won’t update anything unless specifically instructed to by BMW Motorrad themselves and can be unhelpful with software queries.
A year ago when I enquired with this same dealer about having my new to me K13GT software updated I was asked if it started and ran. When I answered yes they sarcastically replied ‘Well it has the latest software on it then.”
When I pushed further I was told that it could not/would not be updated.
A day or so later when a friend of mine who is a valued customer to this same dealer asked the same question on my behalf he was told “As long as he (me) signs a disclaimer that if anything goes wrong then he accepts any and all responsibility then we will charge him £35 for the privilege.”
No prizes for guessing why it didn’t go back to this dealer last week for its annual service…
-=Glyn=-
« Last Edit: February 18, 2024, 11:46:52 am by GlynH »
Offline Nin
« Reply #6 on: February 28, 2024, 07:59:37 pm »
Yep, same as yours (as in, it hasn’t been updated)
Factory - K024-09-02-500
Actual - K024-09-02-500
« Last Edit: February 29, 2024, 12:34:05 pm by Nin »
Offline GlynH
« Reply #7 on: May 17, 2024, 07:05:26 pm »
I know I said in February that I've never had anything other than the normal OK for oil when coming to a standstill at traffic lights but today instead of OK I saw the <!> exclamation mark between two brackets displayed instead. Me and my big mouth! :-X
This probably because I never got the bike serviced in February when it was due although I've only done 2000 careful miles since the last service.
I came back from a run, popped it on the centre-stand, unscrewed the dipstick, wiped it and put it back on the tank just resting it on the threads rather than screwing it back in as per the manual and it was bang on the Min mark. Done this a couple of times just to be sure and it's pretty consistent so happy that the oil level warning is doing its job.
Tomorrow morning I'll take the car to either NOG or Rybrook (depending upon where I decide to go for breakfast ;D) and pick up a litre of BMW Advantec 5W/40 which looks like the usual fill according to the service receipts.
In fact I might go the whole hog and get hold of 4 litres of oil and an oil filter and change both some time soon.
What would be good to know would be the difference between the Min & Max marks on the dipstick so I can half the amount and top it up to halfway between the two as I've never been a fan of brim filling any oil tank.
I have the K1300GT but guessing this is the same tank as both the R and S and was wondering if anybody knew how much oil it would take to fill from Min to Max to give me a steer please?
Thanks & kind regards,
-=Glyn=-
« Reply #8 on: May 17, 2024, 08:58:25 pm »
Approx 0.5 litre on a K1300S from Min to Max (on the sight tube, not dipstick).
But I would trust the manual method rather than the dipstick, i.e warm the engine fully, put bike upright/on centre stand, and then look at the sight tube.
« Reply #9 on: May 17, 2024, 10:23:57 pm »
i.e warm the engine fully, put bike upright/on centre stand, TURN OFF ENGINE AND WAIT 30 SECONDS and then look at the sight tube.
The manual method is always the best and is what is recommended in the manual...which is what makes it the manual method  :)
Offline GlynH
« Reply #10 on: May 18, 2024, 10:47:45 am »
Thanks for the replies.
When I went to school the manual method was the dipstick!  ;)
I can’t stand these electronic oil level displays like I have on the car…
Strangely my GT owners manual doesn’t mention the sight tube at all and refers to the dipstick procedure.
The sight tube you are referring to I assume is the tube with the corrugated section seen from the right-hand side of the bike?
There are no markings that I can see other than the beginning and end of the corrugations so I can’t tell where the correct level might be?
Plan is to pick up 4 litres of BMW Advantec 5W/40 from Rybrook shortly along with an oil filter & crush washer as that gives me the choice of whether just to top-up (probably @0.25 litres) or do a complete oil change which would be my preferred option as I get to try my shiny new blue oil filter wrench from Wunderlich… 8)
-=Glyn=-
« Reply #11 on: May 18, 2024, 11:03:35 am »
Yes, the upper and lower marks on the sight tube compare to what you would have on the real dipstick as Max and Min levels.
If you are the sort who can get off the bike and hold it upright without it falling on you (like Richard, unlike me) then you can check it off the stand but it must be upright and not on the sidestand and the 30 second wait time is because it is a 'damp sump' (© Stormin Norman) setup so you have to wait for the oil to settle back in the oil tank and sump.
Offline andym2
« Reply #12 on: May 18, 2024, 02:41:36 pm »
btw, Rybrook is now Sytner and they've finished the traffic lights so you don't need to go through the housing estate/building site to get to them.
Offline GlynH
« Reply #13 on: May 19, 2024, 02:54:26 pm »
I can barely hold it upright sat in the saddle with one-and-a-half feet on the floor!  ???
It would have been longer than 30 seconds for me to get into the garage, grab a rag, go back outside, remove the seat and check the oil but I’m sure all was OK.
I put @250ml in this morning and got the check mark back on oil level instead of <!> and following the above method the oil level is now mid-way between Min & Max on the dipstick so all good and seems to prove Rich’s theory of 500ml between Min & Max so thanks for that.
-=Glyn=-
Offline GlynH
« Reply #14 on: May 19, 2024, 02:56:16 pm »
Never noticed the rebrand but did notice the traffic lights working and access to the road was open the last time I went there.
-=Glyn=-
