Having had both lambda sensor and idle control valve problems, the symptoms were different. Idle control valve symptoms were just the engine sometimes died as you decelerate. You could immediately bump start if still moving or restart if stopped. Lambda failure gave rich mixture, increased fuel consumption (35mpg), lumpy idle.
