Well, I made a battery clamp today, and it made no difference.
Then I looked at the centre stand, thinking the springs might be weak. I was about to zip-tie it up tight for a test, then I realised I could wobble one side about 2mm in and out. The metal bushing and centre stand hole have worn and elongated by about 2mm.
So.. I thought.. that must be it! Removed the centre stand and.. Nope! Still sounds like a washing machine when going over rough surfaces :-(
I previously thought it must have been the radiator - one of the plastic shims that goes inside the radiator hole was missing. fitted a replacement a bit ago... no difference.
I did have the panniers on, so i'll try again tomorrow with them off.
It sounds really hollow and boxy.. like the headlamp assembly is wobbling - but I'm sure it isn't - it is clicked down on dipped like it should be.
What happens is that you go over rough surface like pot holes, and the front goes "cha-dump", and then the rear does the same, although the rear is much worse.
Steering and everything feels great, and apart from this, everything feels alright.
I have done quite a few things on it and really this was to be my keeper. I bought a well used example but thought I'd be able to make it good..
- discs rattled forward/backward - new discs and bobbins fitted. great, except at <5mph there's a squeak like a finger around a wine glass from the front. sounds like a wheel bearing but I'm sure it's the disc making harmonics
- both front ball joints replaced
- wilburs front shock put on because i thought the front one wasn't working. didn't seem to stiffen between comf/norm/sport anyway, and looks like a k1200 item that's been spliced in. and I thought this might be my main source of roughness/noise
- baffle insert for Remus Ti exhaust acquired
- OEM exhaust acquired
- barnett clutch plates put in
- clutch basket re-engineered/improved by that fella up near Leeds. I had him do as much as possible, including new damper springs and rivets.
- both mirrors replaced (£150 each) because the pin-detent had worn.. so the wind flopped them inwards
- the bloody indicator switch was flapping all over the place so £150 on a new left hand switch gear. Even new they are wobbly and crap, but at least it's how BMW meant it to be now
- new tyres of course
- updated/flashed DME and other ECUs with BMW ISTA/P
