I'm awaiting a new set of plugs for the bike and with most of the gubbins out of the way decided to check the valve clearances.
I need to reshim five inlet valves and two exhaust valves. Will order three new shims tomorrow and play musical chairs with the other four shims to set the clearances within tolerance. All clearances are on the wide side.
Had to make a couple of hold down tools to keep the camshafts in position as the camshaft clamp nuts are removed. Made them out of a couple of old spark plugs with the electrodes and porcelain removed and some studding. Worked surprisingly well.
Have recorded the sizes and positions of all the spherical spacers which will allow me to order in the required shims before the camshafts are removed on future services.
I wonder how carefully the valve clearances are checked at the dealers? Suspicious that the valves rarely require adjustment or am I being cynical.
