As ever Jay, if you put your bike model and age in your profile it really helps those who are trying to help you if you have problems and saves them scrolling all over the place trying to find it.
Assuming your bike is younger than about five years old it will definitely have the later cam-chain tansioner and jump guard fitted in production. Older than that (approximately, can't remember the exact date) and it should have been done as part of a 'campaign', a recall in any other maker's terminology but BMW don't 'do' recalls unless forced to! This was all to prevent the terminal engine failures caused by the chain jumping the teeth on start-up and letting the pistons hit the valves!
Depending on use, mileage and service history it could be a case of the seal in the cam-chain tensioner needing replacement. It also depends on the 'noise'. A rattle on start up, especially when cold can point to the seal needing repacement as the oil seeps out of the tensioner when stationary and then the first rev or so of the engine is with a 'slack' cam-chain as the tensioner waits for the oil pressure to build up so it can do its job properly.
If the engine is simply running noisier when cold then that is a different matter altogether.
Brian (who is a great lover of sticking plasters
