The MityVac doesn't seem to have the radiator cap adaptors for use when re-filling the coolant system.
You need a vacuum puller for use with any of the filling kits; either a compressor or a vacuum cleaner.The MityVac doesn't seem to have the radiator cap adaptors for use when re-filling the coolant system.
I use a Sealey coolant system vacuum filler kit in conjunction with a Pela 6000 vacuum extractor to creat the vacuum.
