OK can one of you chaps explain to me how I can make Nikolai Tesla's approach to electricity work so all my vehicles can work from taking a feed out of the earth please?
I think this is referring to building induction loops into the road (like a big transformer). Pass a current through a wire wrapped around an iron core, which generates a magnetic field. The magnetic field then reacts to a similar set up in the vehicle driving along the road, but in reverse, so the magnetic field causes a current to be generated in the wires wrapped around another iron core, and this current can run your motors or charge your battery, on the move. No stopping to recharge ever. It is very similar, but more elegant, to Brian's suggested electrified chicken wire. It is very well proven technology, as millions of AC motors run on exactly this principle. It does require you to dig up all the roads though to install it, which is a bit of a drawback. Plus they would need to come up with a way to charge for the energy you are taking out of the road, but I can't see that being a major obstacle if you can solve the installation bit.
