Your opinions on this are most welcome.
Had a nice 100 mile bimble on the K on Saturday, but arrived home and tried restarting the bike but the battery was flat as a proverbial pancake. The bike is always on a trickle charger when not in use and the battery is only nine months old.
So, charged the battery overnight and the bike started immediately and ran without fault. I connected a multimeter to the battery and these were my findings :-
1. Battery without engine running 13.2 Volts (should be as I charged it overnight)
2. Engine running at 2K RPM, the multimeter reads 13.7 Volts.
3. Engine running at 2K RPM, with full beam, heated grips on low and cooling fan activated, the multimeter drops to 12.4
Volts.
I'm no technophobe with performance figures for this, but It would seem that the alternator could be on the way out. It was only serviced by North Oxford a couple of weeks back and I did notice a slight smell of burning when I arrived home, but thought nothing of it, old oil etc on hot surfaces.
Anyway, I've sent off an e mail to NOG and have asked their opinion on the matter. Luckily, I have the extended warranty to cover the cost if necessary.
Again, your opinions on those multimeter figures are indeed welcome.
