Hi all,
I've just bought a motoscan and one of the possible options is to "re-calibrate the ESA". Now I know what it does (thank you google), but I'm unsure of why. Certainly, if you swap out a shock from another model, like changing a GSA shock into a K, I can see the need as it needs to set the max and min for the particular bike. But in normal day to day service/use, if you haven't changed anything, and your shock is working away fine, to the best of your knowledge, is there any need/advantage to re-calibrating it? Does it lose it's settings over time? Or is it a "don't push the red button" scenario?
