A forum search may not reveal as much as you might hope, because the search facility isn't obvious or documented.
Use the Search button next to 'Home', not the 'simple' search box at top right.
Basics
Here are some examples of how to search:
Search -> hand guards + select 'Match all words'
- find posts with BOTH 'hand' AND 'guards', anywhere in the post
Search -> hand guards + select 'Match any words'
- posts with 'hand' OR guards' in them
Search -> "hand guards"
- posts with the exact phrase inside the double quotes
Search -> guard*
- posts with 'guard' plus any other letters
Search -> hand -guard
- posts with 'hand' but NOT 'guard'
Useful
Consider plurals when searching:
guard
guards
You will get both sets of results if you search using:
guard*
The 'Show results as messages' option avoids having to open each message to read it fully.
Notes
There is no 'near match' within the site itself. If you or the poster spell a word wrong, it won't be found:
- helibars (69 matches)
- hellibars (1 match)
If you need 'near match' searching, then try an external engine like Google or Bing to search EuroKClub. An example search of the site is:
hand guards site:eurokclub.bike
The external results are of variable quality, I've found.
Searches take no notice of upper / lower case.
Phrase searching needs double " ". Single quotes ' ' don't work.
A minor downside of using the * is that the searched word isn't highlighted in the results. You'll have to scan the posts for your words, or Ctrl-F and search the HTML page.
