Hi Lachlan and welcome to the madhouse that is EuroKClub; I think we only need one member on Easter Island and we truly have spanned the globe
Costas has given you all the info you need to get the switches etc sorted. Although the vibes, as he said, normally live in the K12, mine was never too bad and the Grip Puppies sorted out most of it. However, as you can read elsewhere in here (if you do a search for 'vibes', 'vibrations' etc) mine suddenly began to sound like the engine was falling out, literally!
After a little delving (and a new torque wrench) I discovered that almost all my engine bolts were merely 'nipped' with some being less than finger tight. This happened suddenly and after vibe-free(ish) riding for 3 years on the bike. I merely tightened all the bolts in the correct sequence as listed in the REPRom (BMW workshop manual, available for about £20 as a download from t'internet or for about £100 on DVD from your local dealer).
I would also make sure that your bar end weights are tight, although as he dealer will (should) be changing the switchgear under the general recall, they will tighten them afterwards, (if they need to remove then, can't remember off-hand if they need to come off to change the 13 switchgear).
Hope you get everything sorted and do make sure you let us alll know the outcome.
Brian (who thinks there is something wrong with someone working in Malaysia and getting time off for a holiday
PS What a great Scottich name you have there.
