Author Topic: Engine k1200 work in a k1300?  (Read 3377 times)
Offline doug
  • 713-464-8733
    • www.livingtreesandshrubs.com
  • My K bike model:: 2009 BMW k1300s
  • Modifications and add-ons:: dirt bikes
« on: October 29, 2018, 03:52:24 am »
I have 2009 k1300s with a bad rod and I have a 2007 k1200rs engine will it work will the ECU or can it be programmed? Sorry it's k1200r
« Last Edit: October 31, 2018, 01:31:47 am by doug »
Hi my name is Douglas R Stujenske I,ve been riding all my life I have owned 20 bikes. I had 2005 k1200s it had all the problems the trans, clutch and the final drive. now I ride a 09 k1300s.
Re: Engine k1200 work in a k1300?
« Reply #1 on: October 29, 2018, 07:11:34 am »
Isn't the K1200RS the "brick" engine? If so, they are totally different to the K1200/K1300 engines.
Offline stevel
« Reply #2 on: October 29, 2018, 07:52:31 am »
Depends if it’s the K1200RS from pre 2003, or the 05 - 07 K1200RS that’s like a K1200R with a bit more fairing. If it is the first one, it’s a definite no. The latter might fit physically, but there would be problems.
Even a K1200S engine into a K1300S bike would be a challenge - the ECU would have a different fuel map for starters. It migt run, but I don’t think it would be satisfactory.
If it helps, I have a K1300S engine going spare - price depends on which bits of it you need!
Steve
« Reply #3 on: October 29, 2018, 09:30:24 am »
Steve
Ah!, you meant the K1200R Sport.
[geek]
The RS in K1200RS stands for - ‘Reisesport’ (travel sport)
The R of the K1200R Sport stands for -  'Roadster'
So a designation of RS is different to a designation of R Sport.
[/geek]
« Reply #4 on: October 29, 2018, 11:52:27 am »
Steve
[geek]
[/geek]
I always thought that RS stood for Rennsport.
« Reply #5 on: October 29, 2018, 12:50:05 pm »
Steve
[geek]
[/geek]
It used to ...
The RS designation appeared for the first time at a 17-round series for production racers. On the 1939 R 51 RS, it stood for 'Rennsport' (race sport) with the 'SS' designation standing for Supersport. From 1976 the 'RS' description became known as 'Reisesport' (travel sport), and has since been joined by 'RT' (Reise-Tourer - travel tourer); 'LT' (Luxus-Tourer - luxury tourer); 'C' (Cruiser); 'CL' (Cruiser und Luxus - luxury cruiser); and 'GT' (Grand Tourisme).
http://www.vrakas.com/tips-a-tricks/108-what-does-rt-gs-mean
« Reply #6 on: October 29, 2018, 02:36:14 pm »
You just gotta love a self-professed geek  ;D
Offline doug
  • 713-464-8733
« Reply #7 on: October 31, 2018, 01:33:19 am »
yes k1200 r
Offline doug
  • 713-464-8733
« Reply #8 on: October 31, 2018, 01:41:54 am »
Even a K1200S engine into a K1300S bike would be a challenge - the ECU would have a different fuel map for starters. It might run, but I don’t think it would be satisfactory.
If it helps, I have a K1300S engine going spare - price depends on which bits of it you need! Thx. Steve I'm going too have the engine out in two days most likely needs a crank & rods . Or do you have engine for sale? I don't need trans or the clutch.
Steve
Offline doug
  • 713-464-8733
« Reply #9 on: October 31, 2018, 01:59:24 am »
  Never been called a geek LOL
« Reply #10 on: October 31, 2018, 08:55:30 am »
Keep up doug, he was talking about David.  ::)
« Reply #11 on: October 31, 2018, 10:48:37 am »
 ::) ;D ::)
« Reply #12 on: October 31, 2018, 11:24:22 am »
I resemble that remark! :D
« Reply #13 on: October 31, 2018, 04:55:32 pm »
In which case you've changed since I last saw you David. ;)
« Reply #14 on: November 01, 2018, 02:17:53 pm »
The ECU can be reprogrammed at a dealer only the cost is 65euro. Only to work with an engine version in prpducrion after 07/2008. Older engines S AND R  model can work with their own ecu and zdf in the k1300s chassis with only a few limitations. The R Sport engine  is an older version the answer is no.
