Buongiorno riders, my 1300gt started stalling when about to stop with the clutch in and no throttle, it does not do it all the times but never gives warning before doing it. Any ideas please. Grazie
I had EXACTLY the same problem..... it turned out to be a bad spark plug coil...... (aka 'stick coil')
PS.....I recommend changing all 4 of them, as I did.
Further to my previous post (above)..... Prior to renewing, or even suspecting that my problem was the coil sticks, I removed the airbox and cleaned the icv, followed by resetting it via my GS-911= Problem still present.......I then tried adding injector cleaner to the fuel tank....=Problem still present.
Only then did I remove the coil sticks, one of them had a black, burnt look inside the stem of the stick, It was clear that the spark had been randomly 'tracking' down to earth and randomly cutting the engine at tickover. Anyway, 4 new coil sticks and the bike runs as well as ever.
Its worth noting that the GS-911 did not flag any problem with the coil sticks.
