Having watched videos to do with the K12R and k13 clutches, especially Patrick Hofmann’s and 404’s (sharealike1), it’s apparent oil distribution is a problem. The individual plates can go from soaking with oil to completely dry within the same pack.
I was into my K12 clutch, my K13 clutch and most recently an unused 2015 clutch pack. The pattern of oil throughout all packs was very similar. The exception being the hub area of the K12 where the first hole was not low enough.
Making small changes with the steels and/or hub, I will go for a ride along the same route. Returning and immediately get the clutch out and on the bench, 12 minutes. The judgement of how much oil is on an individual steel is subjective but it is relative. So I’ve been trying to even the oil distribution out. The structure of the hub is a big challenge. I always run the bike with the clutch disengaged before shutting her down. Also should mention that I upgraded the oil pump.
The photo shows how I’ve been keeping track. The heavy bottom line is the hub. The heavy upper line is the pressure plate. The horizontal lines are the steels with the spaces being where the oil holes are. One hole delivers oil to the bottom of the steel above and the top of the one below. On the right, in circles, are the oil hole distance from the hubs lower surface. The underlined numbers are the steels, again using the hub as the starting point. Changes are noted in the top of the columns. Notes on the steels are to the right.
Oil is always moving through the clutch pack. When engaged the oil is preforming one of its rolls, removing heat. BMW over the years has reduced the size of the individual friction pads. This opens the space between pads for oil to flow and carry away heat and debris.
For some reason I’m not very popular at cocktail parties!
Not sure if the photos came through OK?
https://share.icloud.com/photos/0Az17eYDYWyDvt2odYWa8zx9whttps://share.icloud.com/photos/0X91R8qCvduOBL_TinNYFipIw
