Author Topic: Keep the winter rust at bay with ACF-50!  (Read 8770 times)
Offline oilman
    • Opie Oils
« on: September 21, 2016, 11:45:57 am »
With summer coming to a close, autumn is just around the corner. Of course, once autumn is out of the way, we've got winter to look forward to, and we all know what the greatest danger to our vehicle over winter is...RUST!
Opie Oils can help you keep the rust and corrosion at bay, thanks to our new star product, ACF-50 Anti Corrosion Formula and Corrosion Block. If you've got a car, motorbike or boat that you want to keep in pristine condition, then you may want to have a look below...
ACF-50 Anti-Corrosion Formula
ACF-50, Anti-Corrosion Formula, is a state of the art, anti-corrosion/lubricant compound, that has been specifically designed for the Aero Space Industry. It can be described as an ultra thin fluid film compound which must be applied on an annual basis. ACF-50 actively penetrates through the corrosion deposits to the base of the cell where it emulsifies and encapsulates the electrolyte, lifting it away from the metal surface. ACF-50 then dispels this moisture and provides an atmospheric barrier which prevents any further moisture contact, thereby keeping the cell inactive.
This compound continues to actively penetrate and "creep" into the tightest of seams, lap joints, micro cracks and around rivet heads, dissipating the moisture, even salt water, in these corrosion prone areas. These unique abilities of ACF-50 remain effective for 12 months, gradually disappearing as it is chemically consumed.
- Approved for use on Electronics
- Non-Flamable, non-toxic
- Contains NO solids
- Remains "ACTIVE" for up to 12 months
- Film thickness is 0.00026
- A blend of ultra-pure base stocks and speciality corrosion inhibitors and surfactants
You can find further information and pricing HERE. Don't forget to use your forum discount to get an additional 10% off your order!
All in all, this is a fantastic product that we are proud to stock - designed as an "all round" corrosion inhibitor that adapts to whatever task you throw at it. Available in a 13oz aerosol, 1 quart bottle (with refillable pump spray), 4 litre container and even a 20 litre drum which is perfect for the workshop.
After a slightly thicker "grease" for your electrical contacts or wheel bearings on your trailer? Have a look below for the next great product from the same guys.
Corrosion Block Anti-Corrosion Formula Grease
It's no secret that equipment downtime, repair and replacement are expensive. It is also no secret that regular scheduled preventive maintenance is cheaper than the repair or replacement of expensive equipment. Available in a 57g tube and a 454g tub, you can view it HERE.
In these days of dwindling maintenance budgets and closer scrutiny of operating costs and procedures, you can show a real saving through preventive control of corrosion.
Corrosion Block can be described as a clean, clear, ultra-thin fluid which leaves a non-greasy atmospheric barrier to protect the base metal on interior surfaces. Corrosion Block leaves no gummy residue because it contains no wax, resin, tar, asphalt, silicone or telfon.
Corrosion Block anti-corrosion compound is a state-of-the-art material developed for the marine industry. Corrosion Block has three superior features:
1. Superior Anti-Corrosion compound
- Kills corrosion in progress
- Prevents new corrosion cells from forming for 12-18 months
2. Works as an excellent penetrant
3. Performs as a light lubricant very effectively
You're probably thinking "that's great, but can it isolate the corrosion byproduct from my beloved electrical circuits?" Well, yes. yes it can.
As well as offering the mentioned benefits, it also has many electrical uses. Corrosion Block has the ability to remove moisture, combined with its excellent penetrating and strong dielectric properties, have brought a number of electronics 'back from the dead' with just one application. The Corrosion Block removes the moisture from the corrosion byproduct, then isolates the corrosion byproduct from the electrical circuit. Corrosion Block can be used in many different electrical and electronic applications without fear of damage. Corrosion block will not harm paint or plastic surfaces.
We're sure you'll find this new range of anti-corrosion products to your liking - at Opies, we don't stock a product unless we have complete confidence in it, so it's got our seal of approval. If you fancy a look at the full range of our rust preventatives and anti-corrosion treatments, you can find them all HERE.
That's about it from us for today. As always, should you need any advice, please feel free to give us a call on 01209 202 949 or drop us an email to sales@opieoils.co.uk and we'll be happy to help. We're in the office Monday to Friday, 8:30 - 5:30.
Until next time!
-Oilman
Use the code EUROK and get 10% Club Discount
email: sales@opieoils.co.uk
phone: 01209 202944
Re: Keep the winter rust at bay with ACF-50!
« Reply #1 on: September 21, 2016, 12:33:32 pm »
A good price on the 4 litre ACF-50 especially with the 10% club discount and free delivery.
« Reply #2 on: September 21, 2016, 01:15:23 pm »
True, and especially when compared to one eBay price of £105 for a quart bottle  :o
Also, not everyone sells the 4 litre container, most going for the quart and the big one.
Brian (whose two bikes are currently done and ready for the next application anytime soon  8) )
Offline oilman
    • Opie Oils
« Reply #3 on: September 21, 2016, 01:20:19 pm »
Thanks for the feedback, it seems this is some very well liked stuff.
Cheers
Tim
phone: 01209 202944
« Reply #4 on: September 21, 2016, 01:44:56 pm »
'We' have a specific need Tim as the K bike radiators have a great habit of clogging, due to the short radiator and then corroding like crazy as the cores are made of aluminium.
There are two kinds of long-term K bike owners, those who use ACF50 and those who have clogging and rotting radiators  8)
Brian (whose K12 rad wasn't treated, clogged, rotted and blew up needing a new radiator >:( and whose K13 has been treated every year from new  ;D )
Offline oilman
    • Opie Oils
« Reply #5 on: September 21, 2016, 01:56:38 pm »
Ideal, glad it's useful to you guys in particular. I've not heard any bad things about it at all, everyone seems to rate it highly, no matter what they are using it on.
phone: 01209 202944
Offline Timbox
« Reply #6 on: September 21, 2016, 06:01:34 pm »
Yep, my GT got the ACF twice yearly and at 60K miles and 3 winters no corrosion anywhere (Ok, thats not quite true, the 2nd Final Drive had started to bubble slightly, but thats another story)
« Reply #7 on: September 21, 2016, 11:38:47 pm »
I think it was TomL who pointed out that ACF50 is rather sticky and will just gather crap to it so if you spray your radiator you encourage the crap.  what is needed is something like a Teflon spray that can stand heat.
« Reply #8 on: September 22, 2016, 08:39:14 am »
You are correct Ron. I think that the fins are too fine on these radiators and that the ACF50 causes the dirt, grit etc to stick and then totally block the airways.
I keep the ACF50 away from my rad.
« Reply #9 on: September 22, 2016, 11:31:46 am »
My K13 was ACF50'd every year by the previous owner and there was absolutly no sign of crud between the fins. Obviously some muck on the front surface as you would expect. I guess crud differs from location to location and we all ride differently in the winter muck  :o
Offline oilman
    • Opie Oils
« Reply #10 on: October 27, 2016, 02:35:55 pm »
Hi all
Just to let you know, the stock delay for the quarts and aerosol variants of ACF-50 has now been resolved - it is back in stock in all sizes and ready to ship!
Cheers,
Oilman
phone: 01209 202944
« Reply #11 on: October 27, 2016, 06:30:07 pm »
I did my bike on Friday but not the radiator. I'm looking for something else to use.
Offline mab1067
« Reply #12 on: October 28, 2016, 08:28:38 am »
Looking to get bike done next week by All year round biker group. Work carried out at local dealer or guy can come to house. Will let you know how I get on and post a bike of bike after process.
Using to commute every day and even with washing etc at weekend, bike is rather dirty. Hopefully this will see me through he winter months.
My only stopping point is when temp gets to 2 degrees and under. Bike will stay in heated garage then.
Mark Barbour
Offline Paul C
  • Global Moderator
  • ...ooh, why not?
« Reply #13 on: October 28, 2016, 10:09:02 am »
Did my bikes on Monday. I buy the bottle and apply it with a brush/sponge/toothbrush as appropriate. Been using it for about 15 years. Excellent. Always seem to manage to get some on the discs though. Plus that first time you stop in a cloud of smoke is interesting. Seems to work through.
GSA, CCM GP450, Moto Guzzi Lemans II. Once had a K1200GT
« Reply #14 on: October 28, 2016, 11:04:58 am »
After watching the professionals do it I wrap the wheels in an old sheet to keep it off the tyres and discs.
