Sorry, I do have one more question before I flush the ABS. All of the reference information I can find deals with the older "servo" systems as on the K1200s. On those you refill the ABS unit directly with the funnel or other method. On my bike, I am assuming that as I purge the ABS unit through the OBD2 command, it will draw fresh fluid from the front or rear reservoir depending on which circuit is selected to activate. Am I correct? I like going in knowing what to expect.
