« Reply #3 on: September 07, 2021, 02:31:18 pm »
Hi Do you have a multi meter?
Yes?
Check the battery under load.
Attached the meter across the battery with the ignition off. Connect -ve terminal then the +ve terminal on the DC setting. If fully charger it should read between 12.7 and 13.2 volts.
Now with the meter still connected press the starter and watch the meter reading. it should fall between 9.5 and 10.5 volts before the bike starts. If it isn't between those values its most likely on the way out or already shot.
Logged
Prevoius bikes:-Ducati Scrambler 800 Urban Enduro, Aprilia Tuono Factory V41100, VFR800 Fi, K1300S, K1300R, YAMAHA MT10 sp, K1300R, K1200R, GSX1300 Hayabusa GEN1, GSXR1000k3, GSXR750Y2K, YAMAHA EXUP RU,NC30-VFR 400, GSXR600WW, XL600R, Z1B, GPZ1100B1, GPZ900R, GS550, Z1B, Z1A, GT380, GT185, FS1E.
