There is one big problem with this comb idea, the fins on the water radiator are not linear. They are sinusoidal in shape, a high amplitude, short wavelength squiggle.
I am sure these combs are designed for cooling radiators where the finning consists of long, straight rows of fins with the cores between them. The rad on the K consists of flattened horizontal cores with the squiggly fins laminated between them, like this sort of thing:
Or perhaps this but turned on its side:
|S|
|S|
|S|
|S|
The net result is that even if you can get the correct pitch of comb, you can't 'comb' with it, you can only poke it in and wiggle it.
Until the design of the rad changes, these combs are useless.
Brian (who thinks it a noble offer Richard, but yet more 'shelf-ware' if you buy more of them)
