When the right - hand switch cluster failed on my K1300GT, it would not perform the pre - start diagnostic checks. The neutral light simply came on immediately the key was turned, without the flashing "Brake failure" warning lights illuminating. Otherwise, except for the fact that the starter wouldn't turn, everything else seemed to work, although I didn't try to put it into gear.
