Thank you for the responses. I got the BMW connector, 83 30 0 413 585. I soldered the number one wire to ground, black wire and used number three wire to the red. The number two didn’t seem to carry any current. The first time I turned the ignition on the Garmin came to life. But it would not shutdown no matter how long I waited when I turned the ignition off. I took the Garmin out of the mount and found power was still going to the unit with the ignition off. This after two or three minutes.
Any ideas? Does something need to be reset?.
Thanks
