So, here's the plan:
1. Buy two cheapies off Amazon
2. At the next tyre swap, get one Amazon one fitted (I presume this is possible by Wheelhouse - they just screw in, right?)
3. Practice battery replacement (as shown by YouTube) on the secodn Amazon one
4. Replace the batteries on the BMW ones
5. Pop refreshed BMW ones on shelf and wait for cheapie Amazon ones to fail
6. Put BMW with their fresh batteries back in
An update:
TLDR: the 3rd party TPMS units work well
once you remove the original one from the vicinity of the bikeIf you have two working & registered TPMS units (i.e. 2 rears, or 2 fronts) near/on the bike then they'll clash, and the TPMS system won't know which is the one inside the tyre.
Steps so far:
1. Buy two cheapies off Amazon. Done. eBay actually.
Step 1a. Visit Andym2 and register the new TPMS units:- admire shiny K1600GTDone! It looks good in the flesh - better than an RT. And some very subtle crash bars added too - none of your mad tangle of tubing like on GSes. Tasteful.
- 'pre-wake' the eBay cheapies, and then register them with my K1300SDone, but only after a Battle of the Dongles:
We tried Motoscan + UniCarScan, then Motoscan + OBDLink, and then finally GS-911. No points for guessing which worked best:
- Motoscan + UniCarScan: struggled to connect the UniCarScan dongle to Bluetooth for some reason, even though it worked fine at home. It also refused to accept the manually entered unit IDs (tried that at home beforehand).
- Motoscan + OBDLink: connected easily to Bluetooth, but Motoscan still didn't see either of the new TPMS units when auto-scanning for them. The auto-scanning also 'lost' the existing two units in the actual tyres in the Motoscan UI, and on the dash. Eeek.
- GS-911 to the rescue: connected easily, re-found the existing TPMS units, discovered the new TPMS units too, and added them as the second pair (you can have two pairs of TPMS units registered with the bike). Andy also added the TPMS ID manually just to see if that worked. Of course it did.
All that was done with the help of Andy's £10 'waker upper' gizmo and his extra dongles.
Thanks very much Andy!
Step 2. At the next tyre swap, get the eBay one fitted Done. Result:
Initially impressive. The dongle worked straight off - no need to re-enable it. I rode out of Wheelhouse, and it immediately read 2.9! Woot. Result. Better than the original battery-failing one. And then 5 miles later - red triangle warning sign plus 0.0 pressure. Eeek. Park up, examine tyre. Perfectly solid and pumped up. Switch bike off, and on again, and the dash is back to reading 2.9 again. Off we go, 2 miles later, red triangle. And so on - all the way home.
Grrr.
[EDIT]
The solution is to remove the old TPMS unit from the vicinity of the bike, and then re-test.
I had the original BMW one in my tank bag whilst riding home, and it with it's weedy battery it occasionally managed to connect to the TPMS system, and of course then showed 0.0 + red triangle.
Final impression: the cheapie works OK. Happy days.
3. Practice battery replacement. Next step.
I now have a genuine BMW one after that, which (if I can manage to extract and replace the battery) I can re-use when the second BMW one fails.
