Assuming they haven't swap the seat with some other, then possibly install it without the supporter or the spacers they have the tendency to forget spacers lately, believe that installing a seat adjuster the wrong way is impossible but then again dealers can make everything possible.
Is it possible to install only the front adjuster? that do not know.
If you have the cd check the part visible to see if all are present.
