This paper aims to provide:
1. Information to understand the function of oil immersed clutches commonly found in power sports applications.
2. Review the role played by lubricants in wet clutch applications
and the key properties affecting operation.
3. Highlight common problems associated with oil-immersed
clutch operation.
OVERVIEW:
By definition, a clutch is a coupling used to connect and disconnect the powered and driven parts of a mechanism. In this case,the clutch connects and disconnects the engine (driver) and the transmission (driven). The advantages a clutch provides are clear because without the clutch, there would be no way to stop the movement of the vehicle without also stopping the engine. Severing the connection between the engine and transmission removes the load from the transmission, making it physically easier to change gears.
Removing the load also minimizes stress on gears and shifting mechanisms, thereby extending their life expectancy.
TYPICAL CLUTCH COMPONENTS AND
FUNCTIONS:
Manual clutches used in power sports applications are comprised of a number of components. Though their design will vary from one application to another, similar key elements are common: the clutch basket, clutch pack (plates), inner hub, pressure plate, tension spring(s) and actuator.
Spur gears, common in metric bikes transfer rotational power from the engine to the clutch basket.
The inner hub sits inside the clutch basket and is connected to the input shaft of the transmission. There is no direct connection between the inner hub and basket, so if the engine is running, the basket rotates freely around the inner hub.
The clutch pack is located between the hub and basket. The clutch pack consists of an alternating series of two types of plates: steel and frictional. Steel plates attach to the inner hub via tabs on the inner diameter. The next plate is a frictional or fiber plate with a fibrous surface coating. The frictional plates attach to the basket via tabs on their outer diameter.
Plates within the clutch pack alternate until a desired pack height is reached. The total number of plates in a clutch can vary depending on model. The more plates a pack contains, the greater the surface area and generally the greater its horsepower and torque-carrying ability. A spring-loaded pressure plate atop the clutch pack applies constant force to the clutch pack. This pressure is obtained through a series of compression-style springs typically ranging in numbers from four to eight. The final key element is a mechanical device that engages and disengages the clutch assembly. Though the design varies, the device is normally actuated by depressing a lever. The lever movement is then transferred to the actuator via a cable.
ENGAGED POSITION: The clutch is normally in the engaged position. When engaged, the clutch spring(s) applies a constant load on the pressure plate, forcing the clutch pack (plates) together. The load creates a high level of static friction between the plates in the pack, causing them to rotate together. In this position, rotational movement from the engine is transferred to the clutch basket, to the frictional plates, through the steel plates, into the inner hub and finally to the
transmission input shaft.
DISENGAGED POSITION: In power sports applications such in our motorcycles, disengagement of the clutch is initiated by depressing a lever on the left-hand side of the handle bars. This action pulls a cable that is attached to an actuator within or adjacent to the clutch. Though actuator designs vary, its purpose is to remove the load being applied to the clutch pack via the clutch spring. The most common way to accomplish this is to compress the spring by pushing the pressure plate away from the clutch pack. This allows the clutch plates to separate, creating a loss of rotational transfer between the plates.
At that time the clutch basket can rotate freely with engine speeds while the inner hub and transmission either remain stationary or rotate at a different speed.
ENGAGEMENT: When the clutch lever is released, pressure is once again applied to the clutch pack, squeezing the plates together. This increases friction between the plates, transferring torque (the force to produce rotation) from the rotating frictional plates to the stationary steel plates connected to the inner hub and transmission. The steel plates begin to rotate and increase in speed until they match that of the frictional plates. When speed is equalized, the clutch is considered to be fully engaged.
OIL IMMERSION AND FRICTIONAL
REQUIREMENTS:
Clutches balance the requirements to lock-up in the drive position and minimize friction and wear during the transition. This balance raises questions on surface compatibility. Not every lubricant is suitable for use in our motorcycle clutch
applications and some specifically recommended for use provide varying levels of performance.
OIL-IMMERSED CLUTCH (Wet-Clutch):
There are two general categories of clutches in power sports applications. One operates partially immersed in oil (wet-clutch) while the other has no contact with a fluid at all (dry-clutch).
A dry-clutch configuration is common on older Harley-Davidson bikes as well as some models of BMW and Ducati.
The wet clutch configuration is by far the most widely-used and is common on Japanese motorcycles manually shifted ATVs and our bikes.
In a wet-clutch design, the oil acts as a heat transfer medium, reducing the overall operating temperature of the clutch assembly. By reducing operating temperatures, the formation of varnish and lacquer on the clutch plates is minimized. When
varnish and lacquer deposits form, it changes the frictional characteristics of the plates, promoting slippage and increased heat.
This effect can result in more rapid deposit formation and the potential for plate distortion. The fluid in a wet-clutch acts like the water used with wet sandpaper, minimizing the build-up of wear debris on the frictional plates. The oil also provides lubricity to components and wear areas within the clutch, such as bearings and the points of contact between the outer tabs of the frictional plates and the clutch basket. Wet-clutches generally last longer and provide more consistent operational performance because they operate at a more consistent temperature.
Wet-clutches can be found in three different configurations.
The first is where there is a separate fluid reservoir for the clutch keeping it isolated from the engine and transmission. An example of this configuration is the primary-drive chain case found on recent models of Harley-Davidson motorcycles (exceptions include Sportsters and V-Rods).
The second configuration is a shared transmission and clutch fluid reservoir. Examples of this configuration can be found on Harley Sportsters and V-Rods, as well as a few metric bikes like the Honda CRF-250R.
The third is a common engine, transmission and clutch reservoir. This is the most common configuration and is found in the majority of metric and European motorcycles as well as ATVs and of course our bikes.
The three different configurations place unique demands on lubricants.
In the first example, oil must be capable of handling lubrication and frictional demands of the clutch and potentially a roller chain or single gear set. In the second configuration, the oil provides for clutch lubrication in addition to the transmission. In the final configuration, the clutch, transmission and engine all need to be lubricated with the same fluid, requiring a multifaceted fluid capable of meeting a variety of needs.
Good wet-clutch performance is extremely important to ensure satisfactory drivability. Frictional properties, cleanliness, clutch material/oil compatibility, anti-foaming properties, shear stability, and high-temperature stability are all important in maintaining the integrity and performance of a wet-clutch system.
Frictional resistance, is separated into two types: static and dynamic friction. The force required to begin movement of a box across the floor is an example of static friction. Once the box is in motion, the force required to keep it in motion is called dynamic friction. It takes less effort to keep the box moving than it does to break it loose. The reason is that it requires less force to overcome dynamic friction than static friction. In power sports clutches, static friction is the force that keeps the frictional plates and steel plates locked together and prevents them from slipping when the clutch is in the engaged position. Dynamic friction comes into play as the clutch is engaged and the plates begin to contact each other. Dynamic friction begins the rotation of the steel plates. When there is enough contact and the forces of static friction are overcome, the steel plates rotate at the same speed as the clutch and become locked together.
The surface condition of the plates affects the amount of friction generated during lock up. Referring back to the box example, it is easier to push the box over a smooth surface than a rough surface.
Remember, in a clutch there are significantly different surfaces:
The rough frictional plate and the smooth steel plate. The resulting force required for the two different plates to grab and lock-up is called the coefficient of friction. A rough plate will lock-up quicker than a smooth plate.
The subsequent graph displays a typical friction profile. As the clutch is engaged, spring-pressure forces the rotating frictional plates up against the non-rotating steel plates. Dynamic friction between the two plate-types increases rapidly, causing the steel plates to begin rotating. The level of dynamic friction remains relatively constant until both plate-types are rotating at the same speed. Once rotation speed has been equalized, undesirable slippage between the two plate-types is minimized by the resistance provided by static friction. The ability to minimize slippage when the clutch is engaged and locked, that static friction is highest just prior to the plates breaking away or slipping. Once slipping, the resistance force is reduced as dynamic friction has taken over.
From the standpoint of operator feel, dynamic friction should have a high and relatively flat trace. This provides a shorter timebetween clutch engagement and lock-up, resulting in faster shifting.
It is also desirable for the level of dynamic friction to decrease slightly as the plate rotation speeds equalize. This provides a smooth shift feel. If there is too much dynamic friction, the feeling is abrupt and harsh. If there is not enough, the shift is elongated and the potential for excessive plate slippage occurs.
High static friction is also desirable as it provides good clutch holding power and the ability to transfer the maximum design capacity through the clutch.
Within the power sports industry, engine oil is the most commonly used fluid in wet-clutch applications. There are other products suitable for wet-clutch applications, but regardless, the introduction of any fluid will affect the frictional characteristics within the clutch. Therefore, it is important to remember the contribution of the base oil and additives in the final product.
Though it is commonly thought that the use of synthetic oils results in excessive clutch slippage, extensive field and laboratory testing have disproven that theory. Properly selected synthetic based oils perform very well and do not alter the frictional characteristics of a wet-clutch and can actually improve their performance and longevity. The type of base oil used has the least impact on wet clutch performance.
The additive chemistry used in formulating the oil has a far greater impact. Friction modifiers can decrease the coefficient of friction within the clutch pack and result in excessive plate slippage.
Some additives like solid graphite or teflon can also create similar slippage. Extreme-pressure additive containing fluids commonly used in gear lubricants should never be used because they can cause excessive clutch slippage and related damage.
