Author Topic: Eventful week or two  (Read 1502 times)
Offline MadMountainbike
  • My K bike model:: K1200s
  • Modifications and add-ons:: Oberon Clutch Mod, K1300 silencer
« on: October 18, 2018, 10:28:56 pm »
So it's MOT time and I decided that my miss matched Metzler and Pirelli tyres were not helping the bike on the road and it was time for a change (see other threads on the replacement Road 5's).
Since the bike was on the abba stand so that I could whip off the wheels I decided to have a crack at changing the final drive oil... Back wheel off and I'm so glad I did, the stuff in there was like treacle. Swapped in some new syntrax after flushing the drive through a few times, all good.
Then round to the front to whip off the front wheel... firstly the previous owner seems to have superglued the mudguard bolts on the left... No chance of getting them off... but with the right pair off I managed enough flex to remove the wheel... Only to spot a big ding in the rim. No idea if I've done it or if it was on there when I bought the bike. I'm usually reasonably observant but completely missed this.
Got the old tyre off and my tyre guy thought the wheel was scrap, told him I knew of a wheelwright in Stockton who specialises in motorcycle wheels and could sort cast wheels as well as lace-up rims... He was sceptical but I let Thersby have a look and after checking for micro fractures etc. the verdict was that the damage wasn't terminal and it was salvageable. They sorted it in a day and my tyre guy was amazed the result was excellent, the wheel is true and needed minimal balance.
So everything is fettled and refitted and it's like a new bike, the road 5's are grippy, neutral and super supple, the rear drive is less noisy, I did the gear lever fix at the same time and that's now less sloppy and more precise and I hadn't realised how rough that out of balance front wheel made the bars feel.
All in all some great improvements with just some simple, sensible maintenance, such a great bike.
« Last Edit: October 18, 2018, 10:31:07 pm by MadMountainbike »
Offline Andysdad
  • My K bike model:: K1300GT 2009
Re: Eventful week or two
« Reply #1 on: October 19, 2018, 04:17:28 pm »
Can't beat a bit of your own maintenance and looking a bike over - lucky call with the front wheel but a pity about the mudguard bolts.
Re FD fluid - IIRC the manual says 230cc but should now be 180cc apparently (can someone please confirm?)
« Reply #2 on: October 19, 2018, 04:44:16 pm »
You are right, it's been covered at length a few times, a forum search will reveal all  ::)
« Reply #3 on: October 19, 2018, 10:45:23 pm »
Yes I vacillated about that, my 2006 manual actually says 180, (I didn't check the RepRom but from memory it gives 180 for an oil change and 200 for a full refill) in the end I filled via the sensor hole to the bottom of the drain plug. That takes you to just over 200 ml (give or take for ooze) and I'd let mine drain for a long time after a couple of flushes as the stuff in there was rank, so I'm happy with that... Famous last words  :)
« Last Edit: October 20, 2018, 08:54:04 am by MadMountainbike »
