I put cheap Chinese levers on my last bike and they worked just fine. So I thought I would go down the same route with this bike.
I put the levers on and all seemed fine. Until I set out today to meet up with Twisty and Jim at Woodcocks Pub near Lincoln.
Once I got on the motorway I could feel the clutch slipping. I could get up to speed but it took ages and I had to be very careful with the throttle.
It dawned on me that the clutch lever could be the culprit. So I turned around and headed for home. Once home I put the original clutch lever back on took her for a spin and all was fine. When I had a closer inspection of the Chinese lever against the original there was a marked difference as shown in the photos.
It was just holding the clutch off by a teensy weensy amount, enough to make it slip in 4th and 5th.
The red line shows the original shape of the Chinese lever.
This one shows the material removed
This is where the Dremel comes into its own. I shaped it to match the original. Gave it a test run and bingo, now it works as intended.
A quick coat of black aerosol even though the exposed bits wont show when installed.
The moral of the story, don't give up at the first hurdle.
The Chinese have a lot to learn about quality control but all's well that ends well.
